Roll on the 20th June
onesnzeros
Quote from: badassdjbynight on June 05, 2008, 07:00:48 PM
You mean like a simple pendulum?  It will swing for quite a while but it's still not OVER unity.  For it to be OVER unity it would have to raise HIGHER than it's original starting position each time.
Archer, Archer, Archer.. such language here on the forums.  Can we please just see it work for several cycles?  OH.. and what happened to the wheel again?  Can you just be humble and honest with us for a few minutes?  I'm interested in the wheel.
babn, you too can see that the device is extremely unextrodinary. Its a lever. and you are correct about the pendulum. Don't hold you breath that you can influence Archer, he is on his own trajectory.
Cheers,
onesnzeros
fletcher
Should be easy for you quinn to turn that reciprocating beam action into a demonstration of OU - connect it to a crank & turn a small flywheel or pendulum which will store the 'excess' energy you think you have created & then give it back when needed - then add a little friction brake to the flywheel for example, as a continuous load [like a pony brake] over & above ordinary system losses, & that should settle any arguments as to your bona fides & claims - perhaps you could even let the flywheel spin up first before applying the small friction load, then see if the flywheel can still increase in rpm, or even just hold its rpm constant, which would be an achievement in itself.
MrKai
Quote from: onesnzeros on June 05, 2008, 07:01:03 PM
Cheney who? You think the world revolves around Americans? You are posting to a global forum halfwit. hahaha. Americans......less than 5% of the world pouplation sucking up 25% of the worlds oil, you are the big oil that ARCHER is talking about. Suck on that.
PS America is going down the toilet, no offense.
onesnzeros
This is, without question, the funniest thing posted today :)
Every word of it, true as hell.
Good lookin' out,
-K
http://herebedragonsmovie.com/ - Join the Cult of Reason!
legendre
Quote from: Man-K on June 05, 2008, 06:56:51 PM
My my isn't it all getting a little bitchy around here, Archers colourful language is starting to make me blush and purepowers accusations of a rope puller hidden in the bushes is a little below the belt.
Hi K,
Like most other janky Free Energy videos on YouTube, it's quite difficult to tell exactly what's going on most of the time. Different people see different things - which of course, is to the advantage of the huckster du jour.
What I saw did not require a hidden assistant to produce the illusion, but that's just my viewing of the videos.. purepower may have his or her own interpretations and impressions.
But the fact that there is no clear consensus on exactly what we're seeing in the video, says a lot about the subject matter therein, and even more about the author. It's funny though, that the 'believers' immediately invented a story about the purpose and function of the control rods.. if these rods were actually moving during the process, wouldn't Archer have pointed this out? After all, without a bunch of mysterious 'control' rods, this is just another lever in a big world of simple levers.. efficient machines all of them, but overunity none.
-L
MrKai
<snip>
Hey to be honest I'm secrectly hoping that noone believes you so I can build a few of them to plug into the mains and make money off the power companies while I sit on my geeky ass and watch dodgy sci-fi for the rest of my days.  :D
...and this would be the second funniest. It was a toss-up between this and Dr. Murder Legendare's new siggy :)
