Roll on the 20th June
You speak motivating words my friend. I have some other suggestions.
Maybe it would be easier to transform your website into a blog. I would recommend either one of these
Blogger.com
WordPress.org (lots of lovely themes you can choose -> http://www.themelab.com/free-wordpress-themes/)
This would make managing it a lot simpler. And of course for the viewers it's a lot more userfriendlier.
Second of all I would recommend your own little forum. Where unwelcomed people can be led off so you can work highly concentrated and only get constructive comments. I hope you will consider these. It will make the experience a lot nicer for both you and us who believe in you ;).
gwhy!
Quote from: capthook on June 25, 2008, 01:20:06 AM
Can you place numerous trigates spaced around a horizontal wheel with the "roller" magnets actually fixed to the wheel to provide continous motion of the wheel?
Why/why not?
If you check the graph I posted in this thread showing the forces through a array this should show why you can not do what you suggest. Sorry I'm not to good explaining stuff.  :-[ .
Rusty_Springs
Quote from: The Eskimo Quinn on June 25, 2008, 03:08:12 AM
Not here to have conversations, just thought i would save a lot of what ifs. a "tri gate" wheel already exists, the concept is not knew, though his use of the magnets to find an old mag train was different. go to youtube and look for magnetic trains there are heaps of them, there are spinning cylinders too.
they work best at horizotal becuase of the unseen flaw for use. the only power they have is standard float, the same as the rods. the power of them is limited to what weight the can support vertically in suspension, as that shows the power of thrust or drive. Additionally spheres have less of a wall than cylinders and cubes, so they work best, yet you cannot make large ones due to the location of the poles. "inside and out" so you can never get the power.
However if you want you can use them as tappers for machines that suffer friction problems, and no you cant spin a wheel to high speed and tap it along, that comes back to 1 tone on either side of a balance beam over weighted by one ounce, you simply have one ounce of power.
The orginal flying ball bearing machine works this way.
On its own it has not a lot of value, as part of a dual system it would be perfect. Albeit i am sure with 5000 dollars worth of the small spheres you could charge a small battery every day. Just dont go vertical they have even less lift, or use it to accelerate a vertical already running that has weight and power.
I thought I should say something because this is a discovery that has been overlooked for a very long time, and I think his use of it in the videos is a good example of it. Dont care what you think of me, a least give this guy a shot, check the mag trains etc and you will see he really does have a good idea for use that is proven not theory.
Hi Archer
To me the maglev or magnetic train is not the same as the Trigate because one uses electromagnets to push and pull through a magnetic field were the other uses permanent magnet, its alot easier to make an electromagnetic system that attracts and repels then it is for a permanent magnet system.
Take Care Archer
Graham
Rusty_Springs
Quote from: gwhy! on June 25, 2008, 06:10:15 AM
Hi all
Gwhy is right as you add Trigates you stretch the field making it weaker and it has been tried by Sean I think.
The only system I think may work with the Trigate is the one Gwhy showed.
Take Care all
Graham
gwhy!
Quote from: exxcomm0n on June 24, 2008, 08:58:17 PM
Hi Rusty/Graham,
I was wondering if you had tried differing sizes/strengths for the tri-gate/roller assem.
Like 6 -  3cmx.5cm for the gate and 2cm x .25cm roller, or vice versa?
Bigger trigate/smaller roller = more velocity?
Bigger roller/smaller trigate = less velocity?
Just curious as I'd (for expenditures sake) like to use the smallest gates/biggest roller combo I can get away with for the combo wheel.
Trigate lift tests are still not done, but should be tomorrow when I get my car back from the shop for a brake job.
Hi exx,
   I have tried a few combinations myself. And I found that a roller mag of about 2x dia and 2.5x length of gate mags produces a lot more force though the array but the draw back is you need a lot more force to get the roller mag in the array in the first place and also there will be more attraction at the end of the array. But when the roller is in the array it really do want to shift.
