Roll on the 20th June
The Eskimo Quinn
actually i was going to use them as arms though gates exactly like i am doing now, but instead of the track there would have been suspeneded trgates with those rollers running through them on the ends. I dont think you will find anywhre me saying they were to fire rods, a shunt was only ever meant as a frition assist, until this discovery.
If a trigate is not a smot neither is this device, a smot is defined as a one way propulsion system but mine loops unlike all others it can feed itself, mine fits it less than yours, yet i still regard it as a smot. nevertheless.
i am loading the first attempt at going past 12 oclock with a vertical start, and a second video after that of some minor interest. well it has my birthday present Davinci lighter in it so it may be worth watching.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
The Eskimo Quinn
actually i am sure it is one of the repair videos where i said i want to leave the aluminuim tubes on the outside because i have another use for them. they are for the roller ends which have never been the arms with the rods, but a sperate mecahnisim altogether, you will see them on the "outside" of the wheel in many shots.
Rusty_Springs
Hi Archer
I need to ask one thing and tell you that you havn't been talking about Trigates for years because I only came up with it this year not 6 or 7 years ago and second I watch your second video and I need to ask are your triangles straight across from each other? because unless its a cam angle it looks like one gate is infront of the other and if this is true you don't get the same effect, also the roller must be in the middle of the two gate fields yours is kicking out to the right so its not in the middle and changing the effect yet again.
Yes you do have to stretch the field to get it just right it like I have said everything is give and take and I'm moving the wall not getting rid of it thats imposible, you are one of I would say hundreds that have did experiments on the Trigate so sorry to say your not the first to see flaws and I have never said it doesn't have flaw unlike you I admit where it can be wrong and see where things need to be change to make it do what I want.
One last thing check your table because I would say its not leaving everytime the way it should because one your table is slightly uphill and two you have the fields to close, also all it needs to do is come in and go out which it has been proven by many to do, while doing that it must also be able to move a load and its been proven to do that to with toys cars and a cart. A load doesn't have to be hundreds of ton to prove something will do work anything more then the weight of what I'm using is enough to show you have enough energy there to push and pull through the gate and a little more to say cut the magnets through a coil.
Take Care and thats the last I have to say on my Trigate because this thread is not about my Trigate its about your gravity/magnetic wheel Archer
Graham
The Eskimo Quinn
only went past two magnets? gee my count was a little more than that on the vid, i think i mange about three magnets in the first vid today, and maybe four in the second, yeah nothing new here
Rusty_Springs
Quote from: The Eskimo Quinn on July 09, 2008, 02:26:21 AM
Yours is a smot my Trigate isn't because it attracts in and repels out thats a gate, so by saying you was going to change your design to go through a gate your saying your design didn't work and you needed to go to a design more like Gwhy put up to get it to work?
Take Care Archer
Graham
