Roll on the 20th June
exxcomm0n
@ helmut
Thanks man!
The next experiment is going to be MkEs from 6 through 9 and 12 to 3, and having the 3-6 area empty, and then seeing how closely I can get the exit and the entrance of the array track
@ gwhy
Thanks for the graphic! It cleared up most any questions I had about your arrangement. Any others I may still have will be answered by experimentation.
Again, aces smooshing there dude! :D
@ LarryC
Yup Mr!
Good "out of box" thinking!
You just inverted the steel ball bearings from being on the outside of the roller, to being on the inside of an MkE and have made this a more economical build without "cheapening" the effect.
Reminds me of the "magnetic field seen as a Q-tip" theory I spouted way back except you've proven it AND used it for advantage, where I was just "cotton gathering". ;)
@ smoky
Damn! Good to see you're still checking in!
I was wondering where you were, as I was figuring the little spat I was having w/ PureP would be right up your alley of O.R. (Occam's razor) thinking.
Glad to see you're still around as the days are becoming more and more exciting!
@ all
In the spirit of all this "free thinking and experimentation" (smooshing)  that's been so fruitfully going on, I wanted to throw out a new wrinkle.
What if you use and MkE (Mayernik Effect, OneWay Gate, etc.) array and just "shorted out" the last MkE by turning it into a trigate with the "point" at the end?
Ima (I'm) gonna (going to) give that a try here shortly when I try out what helmut was asking me to experiment with.
But I was finally able to wash out the bad taste the zealotry of some individuals caused me to have of mathematics and hunted up the formula (c = 2nr) to figure out some measurements I needed for my HHO cell arrangement and really need to devote some time and energy into it as well since it might make me be able to "hold" the ever increasing price of oil to a standstill for a while.
I'll be posting some vids of that too and you'll find them in my channel.
Now, back to my dervish dance of doofus-ness. ;)
When I stop learning, plant me.
I'm already of less use than a tree.
spinner
Hello!
I've been away for the last few weeks. Anything new about AQ's work? Looks like he's still kicking! Magnets prevailed gravity?
Can someone write a (very) short overview for the last 30 pages of this thread? Thanks!
"Ex nihilo nihil"
gwhy!
as regards the oneway gate,
Not much time playing today ( the other half is not a happy bunny  ;) )  but some things I have noticed so far about the arrangement. I set it up on a level surface well as level as a cheap 'spirit level' can measure. It performed much better with an additional tri-gate ( 4 gates instead of 3 ) . It sucked the roller mag in and thrown clear of the end about 30% of the runs I did then realised that the more accurately the roller was placed at the start of the run smack bang in the center of the gates the success rate went up to about 40-45%. What I did find more intresting was that if the roller did not get thrown clear it got sucked back in more or less right back to the start but without so much speed so I tried running it backwards "in on the output, out on the input" this also worked and the success rate was about 70-80%  ???, but the acceleration of the roller was nowhere near as good. Hopefully I will get sometime tomorrow to play more and I will try to get some vids up.
Rusty_Springs
Quote from: gwhy! on July 15, 2008, 08:47:29 AM
Hi Guys,
ONEWAY MAGNETIC GATE....!!!!!!
Thought I would put this up. Needs to have a lot more testing and tweeking but at least in its basic form as shown it  removes a hell of a lot of the sticky spot at the end of the input array..... The picture shows arrangment but is not to scale.
Hi Gwhy
That looks cool and I see what your doing now with the flux comming in, your pulling the flux you don't want from the Trigate going in down so its out of the way of the roller comming in, thats cool mate thanks.
Take Care Gwhy
Graham
LarryC
Quote from: exxcomm0n on July 15, 2008, 01:34:14 PM
@ LarryC
Yup Mr!
Thanks Ex,
I just hope that Archer will try with some steel round bar with his mag array, test it, tweak it, and maybe double his array. I was real disappointed when he doubted that he could get his machine running before others due to lack of magnets.
Regards, Larry
PS: I only had enough mags for a 1.5 mag arrays, which is only one, now I have a 3 mag array for the MkE using the middle steel.
