Roll on the 20th June
Artist_Guy
Quote from: The Eskimo Quinn on August 03, 2008, 05:43:01 PM
The original wheel was rod drive only.
4)the rear of the axel was direct drive to an 18volt scooter motor
I won't be answering further questions on that subject.
For the love of electrons, please answer 4 more.  :) Your filling in the details was handy.
About what diameter was your original wheel? What travel in mm were the rods set up to do? How many rods did it have? And were the weights about as you stated on your build page way back?
I ask this because I have some scooter motors here, and can wind an electromagnet easily enough, I built solenoids as a kid for an electric lock to keep the momma out of the lab. I'm not worried about one winding being off, or a hundred. The thing just needs to do the trick on the current and voltage available (which I wonder is possible or not). One can also peel the top ply off a transformer and use the remainder of the core.
Trick would seem to be to store the interim juice in a capacitor when not being fired, then fire the electromagnet from that though, no?
rc
The Eskimo Quinn
actually again for newbies excuse madsen has no knowledge of physics either.
energy to foot pounds
foot pounds to newton metres
newton metres to kilowatts.
all energy can be calculated in kilowatts it is how eningeers work out how many kilowatts it takes to turn a ferris wheel or any other motor device.
As to the video, http://www.youtube.com/watch?v=gQK7rOCTV14  that is rusty's track with flat mags
As to the electromagnets as i said they were connect directly to the 18volt motor, there were no batteries.
the wheel was arond 45 cm, the rods were in fact around 15cm shorter than the arms with permanent mags from the bases of chess pieces the tubes were clear plastic stems from hand squeeze pumps people use for siphons.
The weights wre lead sinkers as the electro kept smashing the mags into the far end and bouncing back the fact they ened up being the reason it turned was a bonus, as there was a slight hold wall at the top, not much.
i never removed the upper arc, but it may have worked without it, although less likely.
yes a capacitor is always best to fill and feed from
Queue admitted he works with others on the steorn interactive board, and has posted many false outcomes and as with today the remark about the weights on the wheel any engineer knows is flase when one circle is smaller tha the other. if he is not helping steorn intentionally he is doing it through stupidity.
How did the wheel differ from an electric motor? i dunno? it wasn't plugged in.  I imagine you are referring to using a normal motor as the generator, yes that would be the same thing although this was really two motors the first did nothing i was simply using the axel and bearings and somewhere to fix the arms, the one at the rear was the source of power when turning, the firs motor the fan was simply an axel extention that had fan blades i could use to mount the arms.
Picture a fan in you haed with arms on that with the motor as irellavent, then the rear of the fan axel connected to the 18 volt motor axel inline. the fan was simply an axel nothing more.
That's it for me.
PS. all info will in future be loaded to the magdrive site due to the magical way my site keeps disappearing.
http://groups.google.com/group/magdrive
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
madsen
Quote from: The Eskimo Quinn on August 03, 2008, 06:53:07 PM
Thanks for the reply---this is still not right, however.  If you disagree, can you tell me how many kilowatts are in one foot-pound?
Ok, I wasn't clear on your setup.  I'll have to take another look.
The Eskimo Quinn
http://www.bondhus.com/tech-library/body-1b.htm
http://www.unitconversion.org/energy/newton-meters-to-kilowatt-hours-conversion.html
1 foot pound equal 1.35581795 Newton metres
1.35581795 newton metres equals  0.000000377 kilowatts hours
For those not understanding what it means, it means that whateverevr the strenth of push or pull of a magnet which is measured in footpounds of pressure there is a kilowat amount that it is equal too, and as such that kilowatt amount into an elctromanget will produce the exact same amount of footpounds of pressure. In simple whatever an electromagnet will do a permanent magnet wil do and vice versa, the only benefit is, you can switch off the electro magnet so there is never any wall.
For the benefit of those new to this thread.
1 )i did not start the thread
2) i did not barge in, i was sent an email and invited to comment
3) at no time prior to the 20th did i ever claim to have built one with permanent magnets, i was going to try and make the electro mags until every seemed more keen on something everyone could build, and knowing the above was ture of kilowatt energy decided it was also the best route.
4) on the 20th i made a claim i had the rod wheel running roughly but failed to get it working agin when i went to repair it. So no proof was given, so yes the date was a failure as far as even i am concerned.
5) when attempting to add the assitance to the wheel to smooth out the rough running, and having tested large trigates that failed, discovered the mayernik array. which as you have all now seen and has been reproduced, performs like no other array in history has done.
6) I claim no proof from the 20th as none was provided, so too any claims of this existing before have failed in any proof.
7) the wheel i have now runs intermittanly for periods of time, however we know what is said of anything less than perfect. So in that light when it is perfected to run not only smoothly and well but at low power production level connected to a ligtht or other device so this insanity of nothing new will be at an end.
8) i expect to be able to afford the iso for the balance of the upgrades to not simply running but generator level running to avoid claims of no power when load is applied within the next 2 to 3 weeks.
They are the facts, they are recorded and they have never been anthing other than that, other than people making claims i have said otherwise, which records will show as untrue.
Just remember the song and you won?t go wrong.
you not see nothing like .................................
Rusty_Springs
Sorry its not my onewaygate as I have stated the stator of my onewaygate has two flat magnets side by side giving it both poles on ever side not one pole facing up but thats not important, what is important is it shows a system going up and over the hill spin a few times before it stops and it says it was done in march, it shows what I have said that most arrays will go up and over the hill if the magnets are strong enough the problem is keeping it going.
Yet again Archer has shown nothing that will convince me he can make a working wheel and until I see a working wheel that continues to rotate with out any help from anyones hands I wont believe he has achieved anything as Feddy who was a supporter said stop showing nothing videos show a working wheel.
