Roll on the 20th June
MrKai
Quote from: Evg on June 22, 2008, 03:32:12 AM
Archer is still adding text to his Update page.
Evg: Retroactive Continuity. He is attempting to change the past to fit the present. He says:
"Think logic.
A guy comes up to you 6 months ago, and says i can beat thermodynamics, you laugh and say how?
He says I can take a perfectly balanced wheel and make it self strt and accelerate, i havent iron out all the kinks to keep it going but i have managed to get it to produce more energy out than in."
The thing is...that's not what happened. At all. Sigh. I have his original website cached and nowhere does he present himself as theorizing ANYTHING.
Then he sort of tries to claim thru a very...interesting...causation/correlation fallacy that his failure was a success and proves the law of conservation false via some VERY bunk (but familiar) semantics.
So it appears he certainly isn't giving up. Still attacking physics, anyway.
Sigh.
-K
http://herebedragonsmovie.com/ - Join the Cult of Reason!
exxcomm0n
Quote from: INGUES on June 22, 2008, 03:54:50 AM
I think Archer should rebuild his machine out of cheap materials to prove that he can keep a wheel spinning indefinitely.  If it breaks after 15 - 20 minutes of continuous use due to the materials he would still be able to make his point.  Does anyone else agree?
And what's happened to the other builders?  Dusty?  Redriderno?  Exxcomm?  Have you all decided to stop with your builds?
@ INGUES
I can't speak for the other guys, but if you look up 5 posts you'll see my latest plans for build.
Going shopping tomorrow.
:D
When I stop learning, plant me.
I'm already of less use than a tree.
Evg
MrKai
Whatever you say makes a lot of sense most of the time. But it is easy if you have the backing of the general and scientific community behind you.
Unlike the free thinkers who have 95% of their friends and community against them.
The free tinkers do realize that free energy is unlikely to ever succeed, but still they hope and trust their feeling and build, also they explore in unknown territories, without them the world may still be thought as flat to some. (Last part was a weak argument).
So accept that you may be wrong sometimes (5%) and the free thinkers are wrong 95% and for that reason we can accept that you?re an average person.
Rusty_Springs
Hi Power / Exx
The Trigate will push rods in a straight line from say 9 to 3 or 11 to 1 like Gway showed with the design he proposed, it will go slightly uphill but it will never push a rod from 7 to 1.
I know it has the strength for a rod because I have had it push a toy car through and kick it out at the end, Sean has also did the same with a toy firetruck.
I used neomags for it because I found them easy to get and good for doing alot of different magnetic test.
The Trigate had a problem with circluar motion comming in but that could be over come with gravity, say having a set of Trigates at 5 to 6 and 12 to 1, gravity pushes the roller through the bottom set and they take a roller through the top set.
I only came up with the Trigate gate about a year and a half ago so not everything has been tested and there would be ideas out there I havn't thought of that can be tested.
Take Care Power / Exx
Graham
Rusty_Springs
Hi All
Wow I can't beleave that using Archer logic I have been proving FE for years, My Trigate proves it, my corner gate proved it and my one pulse electricmotor proved it, there is no dout with my one pulse motor, it had over lapping magnets right around with a 5% air gap, the iron in the electromagnet attracted those magnets right around to the 5% air gap, so I had no input a 95% rotation and the speed increased wooooooohooooo I did it, I just had to use the electromagnet for 5% of the rotation and to keep it going but that doesn't matter I proved FE.
I could do the same with permanent magnet and not an electromagnet it would also rotate for 95% of the rotation and increase speed, in fact it would be faster then the electromagnet because its only iron, so I have did it again man I'm great I have proven FE I don't have anything that does any work with out running a battery down but thats cool I have proved FE hahahaha.
Take Care All
Graham
PS There are videos of my one pulse motor on the net so if anyone wants to see it rotate with out power I show this at the begining of the demo before I turn the elctromagnet on, tell me and I will post where you can see it.
