ALL PERMANENT MAGNET CIRCULAR MAGNET TRACK DEVELOPED (2)
Started by TheOne, August 31, 2005, 01:42:15 AM
Markus
No,
Did you sent them to: Markus_Rapp@a-e-r.net ?
How big are your movies ? Maybe I have to change a few setting at my mailbox.
regards,
Markus
TheOne
I made 3 years ago a rotor with all permanent magnet (neo) able to turn 359? quite easyly, the only problem is the final magnet, impossible to close the loop, the rotor gain speed and go quite fast but stop instantatly at the end!!
i see your video and i beleive its not possible to close the loop, even with permanent magnet, its just 180? what i see right now, far from 359?, this cannot work, you must show a complete loop to say this stuff can work.
the problem with this design is you must visualize the magnet flu like, you see when you start the with your ball, the last magnet is far from it, so the flu can attrack the ball until the end of the flu (last magnet), but if you close the loop the flu is closed, no attacktion to start the ball until the end. When you are able to visualize that, this kind of track cannot work :(
hartiberlin
Yes, the video is not very convincing....
The ball is just running just around only about 150 degrees, that is not very
convincing... Also it is not accelerating, but just goes sometimes back and forth...
So , there is no real acceleration...
Also you must show several times a loop to be convincing...
Regards, Stefan.
gast
Markus, it seems you have encoeded the video with an MJPEG codec. I can't play it on Win2k using Media Player Classic.
Are you able to convert this video into MPG1 or something other which is conform to a flat windows2K installation?
Thanks a lot.
Regards Gast
