Tesla coil electrostatic
Started by argona369, May 03, 2008, 01:11:45 AM
argona369
just some more notes.
From Colorado Springs Notes,
http://www.bibliotecapleyades.net/tesla/coloradonotes/coloradonotes.htm
invaluable!
?a principle consisting in accumulating energy of feeble impulses received from a distance and utilizing magnified effect?
what is the magnifying effect?
?In using auxiliary condensers in this way circuits are obtained containing no spark gap in which the damping factor was extremely small and the magnifying factor very great?
in regards to the ?extra coil? which frequency or multiple of, was it tuned to?
The secondary ? the primary? Or the combined both?
?It was evident that in such excitation of the additional coil there should be, for the best result, three vibrations falling together: that of the coil, that of the secondary and that of the combined system. In view of the above it is of advantage to place inductance between the secondary and additional coil to free the latter, when impressed vibration is too powerful to allow the intended vibration of the coil to take place readily.?
Inductor to ground?
?Various ways of connecting apparatus when applying condenser Method of Magnifying effects.?
Condenser method??
?so that the charging or discharging of the condenser is controlled by a sensitive device affected by the feeble effects which are to be magnified?
the ?sensitive device? is the glass evacuated tube.
The second drawing on this page, note the electrostatic battery also.
http://www.bibliotecapleyades.net/tesla/coloradonotes/coloradonotes02.htm#Colorado%20Springs%20Notes%20-%20June%201-30,%201899
argona369
a strange little tube.
i'm thinking of a xenon flash tube maybe.
x-ray caution?
Doug1
 Tesla was a funny guy,cruel humor is still funny unless your on the wrong side of it.
It only takes one working trick or thing.Just one. Leave it in plain sight and just enjoy the show.
angryScientist
Didn't this spark gap configuration act as a crude diode?
The electrons tended to break away from the small diameter more than from larger diameter.
