How to make bedini motor overunity ???
Started by capacitor70, May 03, 2008, 12:09:12 PM
resonanceman
Quote from: mscoffman on July 04, 2010, 12:37:21 PM
I am a member of the above yahoo group. They expect their people
to build a precise replica of the Bedini circuit. They don't like to deal
with anything other then that. It's very scientific in that they can
control the environment of the machine but they don't like to discuss
either innovation or controversy.
My belief is that the Bedini machine functions on two levels
simultaneously, the one designed for and one that just happens.
Static electricity (which *they* call "radiant energy") is the
other half of the equation, weak CF cold fusion aligned by
static electricity occurs in the acid/lead storage battery and
is the voltage downconverter. It's very easy to lose the Static
electric part during a motor redesign. Use neo magnets and
move the coil away from the wheel and the coils can no longer
collect static electricity properly.
Bedini almost never uses capacitors, which would help the
stability of his circuit, because capacitors have a maximum
working voltage and the operating static conditions will
exceed that voltage.
Think anything you want, but what you are thinking won't
match all the evidence present.
:S:MarkSCoffman
Thanks  for the link paul
thanks for the insite  on the group Mark.
I will go there and read ......but I will not join.......I never do anything exactly like anyone else.
My biggest motivation for building a bedini  right now is so I can  test  some of my theorys  .......
As I see it ........a conventional  bedini is cool.........but it is only the first step  of a very long  journey
Hopefully  somewhere along that journey will  will find energy independence.
gary
nievesoliveras
[A author=resonanceman link=topic=4624.msg247808#msg247808 date=1278276341]
I have another question...... On a JT  the schematic  always shows  the dots  marking  start of the windings.......... I do not  remember seeing them on any  bedini  schematics ....... can you check your bedini  and  see where the marks  should be?.
gary
This old schematic shows where the dots should be.
Jesus
resonanceman
Quote from: nievesoliveras on July 04, 2010, 09:55:12 PM
Jesus
Jesus
Thanks  for  the  schematic.
I was  thinking the  dots would  be on the same side of the coil......but I was not sure.
Your schematic  confirms that I my circuit is right.
I guess tomorrow I will take my board apart and  see if I have a bad connection or wrong connection.
gary
guruji
Quote from: Pirate88179 on June 02, 2010, 03:28:22 AM
Here is a hint:
Use supercaps instead of batteries as they capture the HV spikes and store and release them as usable power.  Efficiency goes way up then.
I have powered my Bedini motor from my earth battery. (check out my Youtube vids)
Bill
Hi Pirate how do you use supercaps? You use them parallel with batteries to charge batteries?
I have one but this is 2.7v 650F only not good for 12v batteries. :-\
Any help please?
Pirate88179
What I mean is to just use 2 supercaps, no batteries at all.  Of course, the first one will need to be charged up from a power source to 2.7 volts and then, run the Bedini and it will charge up the other cap and also run the motor.  When the first cap is drained, swap caps and repeat or use a switching circuit that some have used to electrically swap the caps in the circuit from run cap to charge cap, etc.
I hope this helps.
Bill
