My first H2O splitting experiment
Started by gast, September 01, 2005, 04:53:30 AM
gast
After complete my selfmade square-wave generator (pulsing DC, max. 30V/48W/f=approx. 100Hz - 20KHz/duty cycle adj. approx. 35-65%) and doing some other experiements with selfmade transformers I tried to set up an H2O-splitting experiment.
I used a powerful 9V battery from an cordless screwdriver and 2 zinc coated metalplates (nothing different was available).
The plates had a distance of ca. 4mm. I used tap-water with a little pinch of cooking salt (nothing different was available :-) ).
I started the generator and test it on several frequencies. The max. ampere consumption was about 300-500 mA depending on the frequency.
But whatever frequency I used, the splitting activity was not better than a pure DC-electrolyses (tested by connecting the battery directly to the plates).
On some frequencies the splitting activity was lower than a DC-electrolyses, but never better.
What's wrong? Do I need more Voltage? (I tested this setup with another battery with 18V (also from an screwdriver), but same result. Okay, altogether more bubbles, but also in plain DC-mode more bubbles. :-( )
Thanks for your hints.
Bye, Gast
Yes, you must use staircase waves for better efficiencies !
gast
staircase waves?
You mean something like this?
              _
         _   | |
    _   | |  | |    _
___| |__| |__| |___| |__ ...
What amount of voltage I need for a good result?
Hmm, do you have any suggestion for a proper circuit?
Regards, Gast
Yes, this type of waves or direct a bigger step after the othe and no 0 volts between..
Inverters have this type of waveforms.Just rectify an inverters output with a graetz bridge..
Try around 700? Hz or double, so around 1500 to 1500 Hz.
A guy named Bob has tried it on the oupower.com forum and had success..
Try with higher amplitude voltages like 120 Volts or so..
Regards, Stefan.
gast
Stefan, thanks for the infos.
But to go for sure (I don't know the voltage curve of an inverter in the moment  ;)):
I think you mean this a) or maybe this b)
a)    /|      /|
__/    |__/    |__
b)    /\          /\
__/        \__/        \__
