bulbz possible hho project and it could be nothing
Started by jikwan, May 07, 2008, 12:05:36 PM
jikwan
bulbz
you make some very nice pictures!
what kind of software/programme  you use?
why the need to seperate the oxygen?
there are 3 main views/theories about oxygen presence in the actual combustion chamber
1 the more the oxygen the more the rust (to valves+piston rings plus of course exhaust pipe
and silencer)
2 ive come across views saying "hho? no problem-nothing will deteriorate"
3 we NEED oxygen to help burn the hydrogen
how can you burn hydrogen without oxygen?
my (actually joe xogens) idea about vacuum electroysis is using the engine's vacuum
from inlet manifold     very VERY powerful suction
your picture about the little fan---i posted the idea a few weeks ago on this site
hell if im going to dig it up
the idea was.............get a fairly high powered cell going (on the bench) and wire a fan to it
just a low powered (encased) belt driven fan
there you get vacuum
because its belt driven.............theres no posibility of electrical ignition to hho
zen is the art of seeing everything and noticing nothing
jikwan
bulbz
man! wered you get the idea no timing adjustments necessary?
ITS CRITICAL no way can you avoid it
hho ignites very fast compared to petrol/gasoline
Bulbz
jikwan...
I used good-old trusty MS Paint to do those pictures  ;D.
The reason I was looking for a way of separating the gasses, was so that the hydrogen can be mixed with normal air, just like a petrol.
I was thinking about how quickly HHO combusts, due to it being a perfect mixture. I thought that maybe, just hydrogen could be fed to the air intake and because it would be a less than perfect mix, I was kind of hoping that this could be a way of slowing down the burn rate. If this can be achieved, it would eliminate the need for timing adjustment, and would make it far easier for the conversion of cars with fuel injection systems, especially the ones that have no distributor.
But all of the above assumes a water fuel cell that could produce enough gas to run an engine exlusively on water alone, so that we could tell the oil companies to shove their fuel where the sun don't shine  :D.
Best regards.
Steve Ancell.
Bulbz
Quote from: jikwan on May 07, 2008, 07:59:08 PM
bulbz
Would your design produce enough HHO to power the engine exclusively without petrol ?.
[EDIT] I have had people asking me if the above question is possible [/EDIT]
Best regards.
Steve Ancell.
Bulbz
Best regards.
Steve Ancell.
