FREE ENERGY USING MAGNETS
Started by nightlife, May 13, 2008, 11:27:44 AM
nightlife
vince, the design you are talking about is like John has in this next video. The C shaped coils that are shown are actually the charging coils and I was going to use them to charge off magnets that would be placed on the outer side of the wheels. Here is a video link to johns design. Thank you for your reply as well as for the links you provided us with.
http://www.youtube.com/watch?v=z8qvSNkiB9M
nightlife
scotty1, that was the first video I have ever seen that utilized both poles of the electromagnet. Your video is the best one for me to use to help explain what I have been saying.
Now just add magnets with reverse polarity?s to the ones you have and reposition your reed switch to fire between them. You will find that you will achieve 100% more torque.
Then put magnets around the outside of the wheels and build some C shaped coils and use them to create energy from the outside magnets. Once you have done those things, you have built what I have been talking about.
Thank you for posting your video link.
b0rg13
Quote from: nightlife on May 16, 2008, 07:31:58 AM
yup i agree thats one of the best mag motors ive seen as well(because it looks simple), Nightlife maybe you can build one based on this and show us some results..
if you want to get out of the rat race,you have to let go of the cheese.
scotty1
Here is a test for those who are curious.
Place a 1/8" dia and 18" long bare copper wire in an E/W direction.
Place a car battery South of the wire...pos terminal East, neg terminal West.
Use a lead to connect the pos to the East end of the wire...
Connect another lead to the West end of the copper wire...leave the neg terminal open for now.
Place a 1" long very thin needle on top and accross the copper wire so it points N/S.
Place another identical needle under the copper wire also in a N/S direction.
Hold both needles on the copper wire with your fingers.
Connect the lead to the neg terminal for a short time until the copper wire warms up.
Keep the needles the way they are facing and first hang the top needle by its center in the Earth's field and you will see that it stays the way it is....
Now take the needle from under the copper wire and hang it by its middle in the Earth's field.
THIS TIME THE NEEDLE WILL TURN AROUND 180 DEGREES.
Scotty.
nightlife
Thanks to a private message I received from rukiddingme, I realized that we do not even need power to create power.
One of my first designs was a magnet motor that was to use three to pass one. I had no luck doing so and I abandon that design. I have recently came up with the understanding that the air gap between to polarity's are strong enough to pull a magnet through one polarity. Therefore we can use two to one and create what most call over unity. This can be done.
WE NOW HAVE A POWER SOURCE WITHOUT THE USE OF POWER AND IT WILL LAST AS LONG AS THE MAGNETS LAST.
