Bessler Wheel Theory by Alex
Started by Alexioco, May 14, 2008, 10:31:22 AM
Alexioco
Quote from: Alexioco on May 28, 2008, 01:31:15 PM
Ok I'm back with duck tape, I'm now off to finish my wheel...
Edit: Weights have been attached, now just the other side of the wheel needs to be attached and I am done, I can't wait
Second Edit: Problem now, the hold in the middle of my wheel, both of them are not dead centre, the wheel turns when its put on an axle and stops when its weight is at the bottom, this goes for both wheels, luckily the holes are not to big, so I might be able to correct this, I have just used geometry to get the centre and I can now see that the hole is slightly off centre...
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Alexioco
Problem now, the hole in the middle of my wheel, both of them are not dead centre, the wheel turns when its put on an axle and stops when its weight is at the bottom, this goes for both wheels, luckily the holes are not to big, so I might be able to correct this, I have just used geometry to get the centre and I can now see that the hole is slightly off centre...
[/quote]
Right now I have glued an axle on both wheels, then tomorrow put a nail through them for extra strength, I then shall attached the two wheels and see what happens, I will also then add a video...
Alexioco
[/quote]
Edit: This is stressful work, its now the next day and the glue should of set, a nail needs putting through now, then attached the other side of the wheel with duck tape and I am complete...
Alexioco
The wheel is complete, but the wheel only turns a half because the axle in not centre, so I dont know what to do, ill post a video if you like...
hartiberlin
Yes please post a video with vocal narration explainng how you wanted to do it and
give it a spin and let it run down.
Many thanks.
