Play vortices...
Started by iacob alex, May 15, 2008, 02:13:24 PM
zerotensor
the fundamental motion is rotation.
start with a singular point.
rotate it.  the singularity extends to the form of a ring.
rotate this ring along a novel axis.
it becomes a torus.
the flow is that of a vortex.
this is the secret.
from dimension to dimension, a common form emerges.
an extended ring, which rotates and involves,
creating a globally helical flow.
the electromagnetic
gravitocentric
nucleus
of reality.
iacob alex
...as a lab-demo.All that we need: an inclined plane and an extensible hoop/ring configuration.
   The "active" fall of a rotational mass(as a free solid state vortex motion) due to gravity vs the "passive" (nonrotational) rise of the same mass,between the same gravitational levels,can open a way comparable to the well known mini-max method of a fluidic power  collector?
          All the Bests!  /  Alex
iacob alex
          Hi Zerotensor!
  Your commencement:  "the fundamental motion is rotation...start with a singular point...rotate it ...the singularity extends to the form of a..." ...and here I attach the address   http://commons.wikimedia.org/wiki/Image:Dotswirl.gif
  If you place this configuration on an inclined plane,it can move due to gravity only.
  Usually,we can name it a vortex-anti vortex pair game on a slope...
  Can it suggest some new designs for a gravity powered device
iacob alex
....this natural fresh energy "language",with the help of mass moment of inertia,the rotational analog of the translational mass.
   The moment of inertia plays much the same role in rotational dynamics as mass does in basic dynamics.
   Masses close to the axis of rotation have a small rotational mass:this means are easy to rotate.
   Masses far from the axis of rotation have a large rotational mass:this means they are difficult to rotate.
   But the moment of inertia of an object can change if its shape changes
   A fall,between two levels,in the gravitational field acts as an energy wave.
   A fall on an inclined plane is analog to a river flow.
   A spiraling trajectory of a mass,rolling down on an inclined plane,due to gravity only,acts as a temporary dam(storage method),a barrier to hold back as a river flow.
   We can increase easy the moment of inertia ,if we use a spiral/vortex mass trajectory,causing a slower spinning and so a temporary energy storage.
   If we get a "heavy" fall and an "easy" rise back of the same mass...can we take the "difference" ?!
iacob alex
   ....it's a suggestion to use "something alike"  the powerful circular moving mass of water or wind.
       A watermill/windmill gets its power from slowing down  a water/wind flow:a vortex shape is a sign of this energy transfer.
       As a "marker", we can perceive the vortices,around the power collector.
       In the "deeps" of a vortex,we can understand a specific shape-reaction of the intermediary fluidic medium,that is played by the inertial frame.
       For a possible gravity powered collector,in an irrotational field(without vortices)/gravity,the only solution is to play this inertial effect,directly.
       To be concise, play inertia at once.
