Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
sparks
@all
    In the below diagram if I close switch A between the 6 volt battery and the cap the cap will charge up to 6volts. I charge the capacitor through a resistor to limit the current and do some heatconversion calculations,  should keep the plasma from melting the contacts also. :D   Then I open up switch A after the cap has topped out at 6volts.   Then I close switch b which completes the circuit for the lc tank whose inductor is the primary in a 6 to 12 volt center tapped transformer.  Now I let this ring until capacitor a is out of juice.  If capacitor B is an identical capacitor will it be charged up to a higher voltage level when all is said and done then capacitor A?
   If I discharge this capacitor through a resistor which resistor gets hotter.  The one that charged capacitor A or the one that discharges capacitor B?
    Any help here from EE's would help.  I guess I could do the circuit but this experiment may have some gross problems I can't predict.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
innovation_station
Quote from: alan on November 14, 2008, 04:07:01 PM
What is Hemf exactly?
hemf is high electro motive force  as tesla calls it ...
i used to call it back emf but this is not the correct title....
this will charge caps extreamly efficiently....  or it will put out constant out put ...  that uses some hot power and converts the rest from hemf ....
this set up allows the power to flow only to the output  because of the 9 coil it will not back feed to the source ... because of the high selfinductance...  ie choke coil   it is contained in a transformer caseing
ist
innovation_station
here is my dwg of my cap charger....
i beleave this to be the center of a tpu...  i have a design im working on to tap the rmf
ist
tune this buy length to 7.5 hz and swipe a magnet past it to start it or .... charge the cap once and place a magnet in the correct place to cause operation .... ;)
HEY theres NO DIODE ::)
the hemf is collected in the cap and dumped to the control  thus running with gain... if a pulser is used  i have seen some neat things with this setup ..  around 2.5hz  you get the ringggg.  it is kool
innovation_station
so how will you make use of this... :P
many fine wires ringggg a bell then maybe some balling wire on top the whole thing ...   can it get easyer yet ....  the answer is yes it CAN
BUT FOR NOW SOMBODY BUILD THE DAMN THING...
dont look like mac is talking....
it is possible that it only produces a week magnetic feild but perhaps a strong rotating sclar or electrostatic feild......
ist
BEP
Quote from: innovation_station on November 15, 2008, 10:11:41 AM
ist
@IS
Nice drawing! Strung something like a dream catcher? What are your plans for the core/core winding?
BEP
