Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
tosky
@MAC
SM's device is more difficult than radio receiver research, because it is seriously conflict to the physical law of energy conservation. I still don't see any practical way of any hope here getting close to the target. All of those experiments is trying normal EE work. Some of them even learning how to drive MOSFET. How is possible to be success.
otto
Hello all,
I wanted to post on Saturday, on Sunday....impossible. The "post" button blocked.
My PC at home is working OK, my internet connection is OK, I only could NOT post!! Now I will try to post from my PC at my workplace.
@wattsup
sorry for your trouble. We already know that the current is not in the wires but on the outer side of the wires so I can use even wires with a smaller diameter without any problems.
It seems that you have maybe something connected wrong? In my tests I saw that when a coil is connected in a wrong way the core heats up. Like a toaster.
When everything is connected as it should be then the core is only warm.
Again how to connect the FG, MOSFETs...
1. the "hot" side from the FG connect directly to the MOSFETs Gate.
2. the minus from the FG, from the power supply and from the MOSFETs Source is connected TOGETHER.
3. the MOSFETs Drain is connected directly to the MOSFETs Drain.
The dot you see in my schematic is NOT a dot so dont connect this point.
Dont connect the scope probe to this TPU. The probe just near the coils.
You saw weird things? Heeey, this is only the start point of much weirder things. You cant imagine what is waiting ....
I suppose that you dont have any light. How can you have a light from a high voltage??
We all saw the videos. On top of the 6" TPU is a "transformer" like from a camera flash. Under this "transformer" is an additional coil wound over a metal toroid. This is the OUTPUT transformer. This transformer converts our high voltage into a usable voltage for our bulb.
So, get a blown PC power supply and there is a transformer, always T1, and connect this transformer as an output for your bulb but driven in the opposite way.This great idea I got from a veeery good guy here from the forum.
Yes, I posted this a few times. Without this transformer you dont have a chance to light your bulb.
You remember the 15" TPU? Dont we see there 2 coils wound over a silver metal? This are the output coils!!!
Of course 2 FGs are a must. You have to mix at least 2 frequencies.
@tosky
we all know the work of Tesla, now is Hubbard in the other thread...
If you look at just 1 coil its a piece of wire with or without a core and the work with such coils is only a EE work. When you have more of this boring coils its still an oridinary EE work until you see effects that are NOT expected. In such a moment the boring work with oridinary coils starts to be an interesting adventure. Interesting because the coils are not working as you would expect.
How is an success possible?
WITH HARD WORK!!
Otto
wattsup
@otto
Thanks very much for your post. I needed exactly what you are saying and will be getting a second FG. I already saw one on Ebay here;
http://cgi.ebay.ca/20-MHZ-FUNCTION-GENERATOR-FREQUENCY-COUNTER-ZAPPER_W0QQitemZ270252412571QQihZ017QQcategoryZ97196QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
It goes up to 20MHz and is much more sophisticated then the one I have which is a 2MHz BK Precision model 3011B.
I have experienced that when I have the system running and I start playing with the FG Duty and Offset adjustment, more often then not I wind up blowing the mosfet. I have blown a good 15 mosfets so far. lol I think I am catching up to your number of blown mosfets. lol
Also, I think I will have to rewind the coils because two of the coils (the smaller ones in the diagram labeled Trigger coils) have been blackened considerably and I am worried the lacquer insulation is gone and is now shorting. No problem and this time I will use the 24 awg as you have.
I know I am a pain in the ass but could you please take a new look at the wiring diagram above just to make sure there is no mistake in the diagram itself. When I rewind the coils and prepare for new testing I will take a photo to show you what I have done.
I am amazed that there are no other people trying this. It is so easy to wind the coils and all.
otto
Hello all,
@wattsup
I already said that you can ask what you want. Youre working and thats very good.
My schematic is OK but you can change something:
The trigger coils must be connected in series. If you have 2 or 4 trigger coils they must be connected in series.
The load coil: if you have 2 cores then you can use 2 load coils connected in series and then connected in paralel. This gives the best output results.
Again, a n output transformer is needed to get a lower voltage on the bulb. This is important.
I made my newest TPU with a 9 turns collector + a Metglas magnetic core + 4 bifilar wound controls in 2 hours or so. Its not so a big job but .....
Otto
turbo
Quote from: otto on July 01, 2008, 12:07:17 AM
Hello all,
@All
Again - How about using a Metglas magnetic alloy as a core?
Otto
It has to be air core.
Using a core will null out and destroy the effect.
In fact anything inside the spinning vortex will interact with it ,even most plastics will heat up and melt at certain frequencies.
This is one of the reasons why you cannot use metals close to the unit aswell as why Stevens units heated up due to eddy currents induced in all the bailing wire inside the field.
M.
