Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
MACEDONIA CD
HELOO   marco  you are still mad of me  ;)
to all
YES IS GOOD  HV  is  llght the bulbs  ;)
yes  clouse to  end  and  away from  true <WHAT IS THE ELEKTRICITY?>
my tpu is vibrating and   expeckt  the  curents to come
otto
Hello all,
yesterday I didnt want to finish my thoughts about the "forgotten" words in some patents.
Over a year ago I wrote about SLOWING DOWN particles. The older members will maybe remember.
I hope the builders saw that for lighting a bulb, the high voltage is totally useless. High voltage = low current. Low voltage = higher current. Of course, not always. Only in our case.
So, SLOW DOWN the particles and you will have a usefull current.
Otto
otto
Hello all,
@Erfinder
I was really hoping to see you here.
I was talking about PURE high voltage WITHOUT caps. Just the high voltage. With this high voltage you cant light a bulb. Im talking about hmmm....say 10 or 20kV.
Of course, when you connect caps to this high voltage everything changes. In a positive direction.
Otto
BEP
So we...
1. Increase the capacitive surface area of this low F capacitor between charges and discharges
2. Change the inductance of this charged coil in a similar way and time
3. Run tests in a time machine
4. Use Ohm's Law but factor in Time
One or more? All the above?
To have HV with low power the time must be short. If you could stretch time for that pulse you would increase the area of the wave which increases the power stored.
A transformer will convert a short HV pulse into a short LV pulse but supply more amps out than in. We need a transformer that will convert a short HV pulse into a long LV pulse. I think the object is to get an output that has a larger wave area out than in.
(The above concept using 'pulse' can be replaced with 'wave' if you prefer no pulses  ;D
>>Edit
The above idea should appear to make sense to most but there is a flaw in the idea....
A pulse or wave is NOT the way it looks on a scope. Power in a wave or pulse is not the area of a slice of the wave (scope shot). The area is the height, length(time) AND WIDTH of the wave.
If this was not true a step-down transformer would also step the power down, not just the voltage.
otto
Hello all,
AHA!!!
Look into the Tesla thread.
Otto
