Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
BEP
 :D
I tripped a 1200 Amp 3 pole circuit breaker with a 14 ga. jumper wire, by mistake, one time. ( phase to phase - load side connection ) The jumper showed no signs of the short circuit. It is amazing how much current can flow in very short time periods.
I've also seen complete PC board destruction with the 'fast-blow' fuse still good. The rated ampacity of the conductor doesn't mean squat unless the circumstances match everything on the ampacity chart.
Anyone having to worry about such run-aways yet?
giantkiller
The vaporization occurs  from the high conductions through the copper. Get above that and the copper doesnt see the force. Skin effect.  :o
--giantkiller from South beach, Maimi.
Antimon
Quote from: Chef on October 11, 2008, 09:30:43 PM
How can the power level increase above the power level, which the copper wire can take, before the evaporation?
Take a power fold of the the device by 10. That means you put 100W into it and you get 1kW from the device. When you get 1100W from a slight instable situation the new factor is 11. The feedback and input is then 110W folded by 11 gives  1210W at the output terminals. This is the basic situation when the device runs away. This will result in an explosion because this happens in a fraction of a second. 1MW in microseconds is realistic.
A.
bolt
I don't think SM is a fraud just no one has been ale to replicate the TPU yet. I have been busy with other stuff for many months since i last checked in but in not sure if anyone is closer to the TPU especially when i see the TPU still being hit with powerful spikes creating massive EMPs. These are very dangerous and as discussed many times no way was the TPU really operated like this as it would be too dangerous to get near the thing at a 1kW.
Things are happening though across the ZPE scene.  We now have working bedini motors charging many big batteries from one small one, Rotaverter and Newman motors and many others these really do work for fractions of power inputs. There are many excellent studies and results on this stuff. So whats happening with the TPU? I dunno i wish i had access to a lab setup to try this stuff but the rotaverter proves a single phase which is pure sine wave signal BTW going into one phase can be capped in resonance to produce a rotating magnetic field of high order resonance!! It does NOT need sharp impulse to make this happen!!  I been saying this now for years the TPU works on sine waves and there is no need to go looking for magic spot frequencies. Its only the ratio between the frequencies is the key not the spot. SM told you many times the frequency of operation s dependent on the size of the coil. Once you have a rotating magntic field which is dead easy any sync motor does this off the shelf then you make sure it runs on resonance  NOW we start dealing with RF circuits because when you match a load to source signal the current input drops rapidly when its in tune. :)
So we are half way next is extraction. Any coil which is running in resonance IS over unity and the trick is to collect the excess by using an extremely small pulse EXTRACTION not input like you been doing for so long on the tpu. If you make pulse extraction you take a  snap shot in time compression where you can take HUGE amounts of current without reflection to the source! Bedini does this collecting the back emf and for a moment in time you can grab this and dump it into the battery. So the trick is this you dont take everything from the river but you can take a bucket full and pour that into your load yet the river still flows and does not SEE the bucket of water missing! You must NOT destroy the original oscillator signal nor does it have to be very strong to start with. Everything about the TPU relies on RF technology but at much lower frequencies. In essence its a folded dipole fed by a balun toroidal where each side of the dipole is fed a low power sine wave in pure resonance and each half of the dipole is configured as a motor in Y format single phase to 3 phase virtual mode aka rotaverter. This will instantly give you rotation which increases the energy.  I would try to AV plug it and scoop this excess power into caps before attempting to loop it. The virtual currents flowing around the system before looping should be 10 or 20 times higher then the input power.
Hope this helps open some ideas.
innovation_station
welcome back BOLT   8)
things would have been much quicker if you were around  :D
glad to see you back
it is all bemf ....
thats the secreat.... ;)
bemf is the back bone the source of free engery
wakie wakie time for the bakee
if we look back in history we will see that ALL magnetic / electric free engery devices have been utilizineing bemf for many years.....
:o
l8r
back to work it never ends 8)
ist
access point power supply is almost up and online.... ;D
