Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Grumpy
Quote from: Chef on October 16, 2008, 06:59:21 PM
So, let's say the energy what the device can release in one second is 100w. That mean, it can release 10 000w of power in 100 second run. Is that mean the energy contained in the device is 10 000w? I think no! The device working like your electric socket in the wall. If you drawn more power that your fuse can accept, like short connect the wall socket with two wire, after you exceed the limit of your fuse, the discharging will stop, and your fuse kicked out you from the system. But if you short connect the wall socket with 5cm, hair thick cable, the cable will explode in a microsecond, but the discharging will stop!
Yes, the discharge will stop eventually. Until it does, the output is conencted back to the input and magnification continues - it only takes microseconds.  Wire is a conductor within a dielectric, it is not the only path for the energy.  Just like an arc across a surface, if less energy is required to make a path, then the arc will follow a longer path and not directly through the air.  This is known as the principle of "least action".
        -Frank Edwards
sparks
     If we take a condensor charged to 1000 volts.  What do we really have.  We say there is potential but what do we really have.  We have more electrons on one plate than the other and no way for the electrons to flow easily to the other.  But what do we really have.  We have a denser energy field relative to a less dense energy field.  That means that the space between the two plates has voltage also with no mass.  So if there is a way to exploit this voltage between the two plates would it effect the mass producing them or would the voltage just keep on coming?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
innovation_station
@sparks
in my experience it just keeps on flowing with out concern to the source.....
ist
as fast as i can short my cap there it is agin :P
anyone know the time??!!??!!??
video time
Antimon
The cap is not safe, because you will not only get your energy from the cap when you feedback, you also get energy from the output, because the cap is parallel to the output. That means there is no protection of run away.
And: The bigger the collector, the more energy you will need to vaporize the copper, the bigger the explosion.
A.
MACEDONIA CD
  hi  to all
                            NICE SWITCHING  PARTS  YOU HAVE PUT  ON YOUR  TPU  marco<>
i hope is not expload like  your  atom bomb<yes
