Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Antimon
Nobody wants that someone dies...
A.
giantkiller
Quote from: sparks on October 21, 2008, 12:30:48 PM
   GK
    Don't even think about bringing that generator of Ed's home for evaluation by an expert.  :)    Any chance Ed had room for an electric motor underneath it.  High frequency generator driven by a low frequency motor?
He had an inordinate amount of Block and Tackles around. I say he used the 'A' frame and a block and tackle as a watch spring. The center weight falls really slow to work a cable attachment to the crank shaft bottom of the generator. He originally used a bicycle.
At a certain revolution the genny spins a compass along side. With 24 n/s n/s n/s n/s n/s magnets the revolutions can be slow and the cycles are still there.
I'll post videos tonight.
I cracked Coral castle mystery...
It is a sextant type map pointing to a inhabited planet. Follow along.
You will notice that there are 2 tables or rail road ties along the front and the right side. Grab on to your shorts! The front has wire tie downs. There he wires down a bottled inductor. The wire loops match the respective ends of the bottles. The other railroad tie is for the variable capacitor. Can you say LC circuit? The long coil on the wall is ceramic core. This is placed in the holder on the other side. It has fat copper of 10#awg. Same as the the flat wire on the wall. Step up/step down, he has the items to do any.
The cross hair wire in the North point is not even straight. A spark gap at 33 feet height. 1500 volt potential at that altitude.
The combinations of different coils and variable caps are for the different mass sizes of the blocks he moved. Why heavy blocks? So they could not be moved in the future. The walls are made in segments. The gaps are only visible from the inside. The viewer is in a clock, chronometer, sextant, compass, resonant cavity. All objects line up with either the wall graticle or celestial objects.
The walls have slat markings where they were cut out from the quarry. The 'Blades' are in the tool room. These slats are smooth like spread clay. No cutting or chisel marks. The blades were put in place and driven in by the generator. Keely did this a couple of years prior to release gold from the quartz in an exhausted mine. The quartz fell to the ground like sand and the owner bent over and picked up the gold with his hand. The hole was 18 feet long, 4 1/2 feet wide and was cut? in 18 minutes. Quartz? This whole place is crystal.
In the interviews with the people on the DVD they never once mentioned machine sounds. Just 'The next day a stone would be erected''.
Well the responses are everything he had was so simplistic and primitive. Guess what? It don't take much.  8)
Ed's Barbecue is a smelter/blast furnace. The repentence room is a blast shield. The strange looking holes are windows with vertical tool manipulation slots. There are 2 of them. You can work the furnace from these 2 windows. The chair is there to sit on while he worked the bellows that feeds the furnace through a pipe below. There are steps on the left of the Repentance room by the beds. You go up the steps and you have access to long metal stock into the smelter.
On the iron door he has the sun, earth/21, and a object on the other side of the sun. The same display is on one of the standing stones. I didn't get a chance to see the angle facing. This also states on the door to 'ring the bell twice'. Why do we ring the bell? One frequency inside another. It is the path of the signal just closing the 1st revolution of the pancake coil.
Look at the 3 bears. One is too hot. One is too cold. One is just right by Goldilocks. PHI http://en.wikipedia.org/wiki/Golden_ratio
http://en.wikipedia.org/wiki/Ursa_Major
This points to the Pinwheel galaxy same one that the standing wave model North of Indian Springs, NV.  points to.
The bright planetary nebula Owl Nebula (M97), named for its appearance, can be found along the bottom of the bowl of the Big Dipper
Of note as a curiosity more than an interesting deep sky object is Messier 40, a double star that Messier nonetheless included in his catalogue. This looks like the cresents.
Then
Ursa Minor  The tail is Polaris, the North star.
47 Ursae Majoris has a planetary system with two confirmed planets, 2.54 times and 0.76 times the mass of Jupiter.
http://en.wikipedia.org/wiki/Extrasolar_planet. Close to the Goldilocks zone!
http://en.wikipedia.org/wiki/Gliese_581_d  Approx 20 light years. I say Ed was right by 21.
If one walks up the steps of the Polaris Telescope / North pointer and turns and faces into the chronometer, on the opposite wall there is an 'alter'. Look straight up for an alignment time. You then go and then stand on the 'alter' and face into the park.  When all the correct alignments are made by the facing chairs onto the wall the sexton will be correctly aligned. This is when the music can be made that resonates the environment. TeleForce.
On the North pointer steps the planets on your left will rise above that horizon. Mars and Saturn. These shadows should also point to something on the wall in the morning.
The 'Turnstyle' had a horn on it that can be blown and in any direction. At the right frequencies and power wave the cresent moons become parabolic focusing dishes. I am sure the angular line up is very, very important.
There is a lounger in the middle. Lay on this and look up to the sky. The angle points to something revelant at the right time of the year when the rest of this chronometer lines up.
The star of David or the Latvian cross appears 3 three times in the chronometer. Ursa Major was also pictured as a bear by both the Jewish people and most North American peoples.
If you take the ED.L. and apply it into the code table of the code144 you get 54.3.
The four stars in the "bowl" of the little dipper are unusual in that they are of second, third, fourth and fifth magnitude.
ISBN: 0-9637467-6-6  8)
Moving the stones was child's play. Read the sextant. Read the chronometer. Follow the map. I was there amongst the tourists and their fairy tail park guides. I know what I saw in real time stoneware. It is still there. Thanks, Ed.
I saw similar alignments in Tulum. It is a solar / celestial stadium. The building shadows point to places on the wall that surround it on the west. And view ports point out into space. Other standing stones point into space. It is not even documented.
--giantkiller. We won't get fooled again.
MACEDONIA CD
hi to all
iM  HMMM   WHAT HAPEN  HERE
TO MANY TALKING HERE FOR ONE DAY
AND STILL NOTHING
IST  LOOK LIKES  WE MAKE RACE HERE  HOW WHILL  MAKE  FIRST  T.P.U  WORKING
HELOO <<<<<<     Marcel ,, Inovation,,  Sparks,,    >>>>>>>
Marco  hmmmmmmmmmm   whereare your t.p.u
          Mannix   say haloo  to S.M   TELL HIM   THAT THE HIS  T.P.U IS NOT HIS  DEVICE
AND  ASK HIM HOW THE REALY  T.P.U  DEVICE  ASK HIM
I WHILL STILL LIVE SOMEWHERE
   YOUR FRIEND FROM  Macedonia
giantkiller
There is a wealth of other things that will crash into your mind, life and soul.You have but to follow instructions.
The red pill or the blue pill. In or out. The choice is yours.
The biggest barricade is yourself. Follow instructions, follow along or fall off.
--giantkiller.
ramset
YES you missed reality  THIS IS NOTHING NEW!!!
Chet
Thanks Grandma
