Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
turbo
Quote from: Mannix on October 24, 2008, 09:02:27 AM
I believe that bolt makes some great points and has an excellent vision .
There are and always have been 2 schools of thought on this and there is no reason why they are not both true at the same time.
Lindsay
SUre but one does not have to go post things like "You should NOT be making this or that" and "So clear your bench throw the old trash out and start making"
Come on men
sparks
   I think Marco is dead on balls.  Cold cathode betatron with the cathode extended to a load you get to heat.  Synchonization with the Earth's magnetic flux so that the electron's kicked loose stay loose and out of the cathode for as long as possilbe.  This is charge seperation.  Charge seperation is voltage. Voltage is power.  It aint the amps,  that's the work , the energy is in the voltage.
  The little betatron in the middle synchronizes the pulses to the big betatron on the outside.  The gain is because the Earth's magnetic field helps to accelerate the kicked electrons around the core of the torroid so the cathode attached to the load stays positive as long as possible.   This is utilization of  partial alignment of a magnetic field with the dielectric field.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
innovation_station
 ;D ;D ;D
speed is power  ;)
lol
ist!
bolt
There are so many reasons why i take a stand on this but foremost by far the majority of TPU builds on here have been coil banging and over the years it has got no where. I yet to see ONE person demonstrate a rotating field with a compass in the centre spinning. Its not hard you use either 3 phase signaling OR rotoverter is dead easy just needs single phase sine. If you think this does not work then you are also suggesting an electric motor does not work either when the principle is the very same thing.
SM has tried his dam hardest to describe the TPU without mentioning the control circuit. Some is cryptic not to confuse but to simply avoid direct confrontation with the IP owners of the controller.
Secondly SM was an audio man he mentioned so many times about purity and hi fi and resonance and backed this up by explaining that the circuit boards had to be hi quality for stability. He also told you to make this first with tubes. ALL of these things you do when dealing with RF or pure audio sine. You do NONE of these things when coil banging.
Third over the last 100 years there have been several power making devices like the Hendershot and Moray which are  cousins of the TPU.  High speed logic and thyristors were not around back in those days nor CPU's to control the timing BUT triode tubes were around and so were sine waves.
I fail to see why SM tried to hide the fact a control coil is a collector and visa versa. Look, very simple if he did not want anyone to know how it worked quite simply he would say NOTHING. He could turn around and say the entire device is owned by another entity and was not allowed to mentioned it at all. On the contrary he has tried very hard to describe it without violation.  So my advice is before you spend money on making another TPU go through his check list and tick  90/90 points and not 10/90 and make up 80 of your own.
Do what he asked you to do. Make a rotating field.  You will see a kick!  The kick is what you get BACK not what you put IN. The faster you spin the  kicks  run with gain. Make 2 of these things to make a rotating magnetic  ball! I don't know why this is so hard you can plug a 3 phase motor casing into the mains and it will give you a spinning magnetic field powered from sine waves. There is no 1500 voltage spikes here!
I can go through his check list and tick 100% of his points and match it with a sine solution. You cant do this with spikes or tesla stuff.
Spider
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
