Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
innovation_station
Quote from: starcruiser on October 31, 2008, 08:29:15 AM
@IS,
Seems that the induction generator concept served you well.
indeed....
oh i forgot to mention the 6 500vac 13uf caps in it too   ;D  wich are charged from the re ...
ist
otto
Hello all,
@IS
i dont say that I dont trust you.
Lets say I want one day buy your TPU. Here in Europe its normal that every product have a declaration (short description) about the characteristics of the device. Input voltage, current,... output power, how many loads, bulbs.......watts, amperes,......
Let us know what you have. I dont ask for your sectets.
Otto
bolt
"IT DOSENT MATTER IT IS THAT SIMPLE JUST AS SM SAYS!!!"
Simply constructed maybe but technically very difficult to get working. Unless you have 2 collectors and 3 oscillators driving 3 gate coils each to give rotary 3 phase-NON reflective AND quench the collectors at 6 kHz with skewed  H B bias for the saturable reactor  mag amp (toroidal core and magnet) then you don't have a 3 Phase PUSH PUSH Magnetic Triode Amplifier that will automatically provide DC across the collectors with 6Khz AC sat on top with open loop gain>10,000 then you don't have a TPU you have a coil banger.
ALL the early versions of TPU had toroidal mag amps but i not seen anyone use them yet anywhere on this forum. If i missed one let me know;)
Grumpy
Quote from: wings on October 31, 2008, 03:59:53 AM
With the right combination of frequencies, you can actually create a revolving field with inertial!
That is what I have referred to as, The inertia effect.
There is a genuine gyroscopic effect when the units are on.
Everybody has noticed that when held and in operation, the units have a definite vibration and have a gyroscopic effect.
They seam to resist being moved through the air.
When placed on a smooth surface it is very pronounced.
Some of you should think about that.
Rotation of field. . ."
Notice that SM says "revolving field" but not a "magnetic field".
So, If you have a device that you think works and no inertial effect - then you should take another look because it probably doesn't work like you think it does.
"Kicks" are what you get out - not what you put in.
        -Frank Edwards
sparks
@wings
     SM is a teacher.   The collector winding in his coil can be treated as a cold cathode inside a ring shaped torroidal vaccum tube.  The initial kick introduced on a potential between the cathode and the outer solenoidal windings (which duplicate the walls of a vaccum tube and also an anode )  cause electrons along the surface of the collector windings to go airborne.  This energy to go airborne comes from the polarization of the space between the collector and the solenoid.
Force one.  The magnetic field polarity of the Earth.  Force two.  The drift of electrons in the intervening space of two perperndicular forces.  Magnetic and gravitational causes the entire collector to go positively charged or cold.  This is a negative entrophy that does not suppose to occur when dealing with energy.  It is the same thing that happens when hydrogen and oxygen implode.  Space becomes more ordered and the void is filled by everpresent energy that heats up mass as this implosion reverberates at tremendously high frequencies.  The gain in SM devices is the hang time of the electrons.  Longer they are out there the longer it takes space to heatup the collector.
     Tesla in the patent that appears again and again in inno's signature states quite clearly (which is rare for Tesla talk )  that there is more current in the energy of his oscillating circuit than in his input circuit.   SM stores the energy illicited by the electron hang time in a rotating field alright.  It isn't rotating magnetic lines of force it's rotating electrons one direction and the holes left in the wire the other.  Does anyone see any similarity here with one of the original betatron tubes where the round filament is inside a torroidal vacuum tube surrounded by magnetic fields?  This design was used by physists in their unending search for field unification, meanwhile the filament degradation (carbon sputters) was overlooked and regarded as problematic.  They weren't interested in having the electrons hang around they wanted to get them the hell out the tube so they could shoot at things.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
