Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
0 Members and 23 Guests are viewing this topic.
ramset
Grumpy  Is there someplace that this can be learned /studied?
Those that understand, were they guided /helped to this knowledge?
Or are they just some really smart fellows ?
       Chet
Thanks Grandma
giantkiller
Telsa did 3 things and 3 things only:
Charge, resonate, discharge. Kapeesh?
Now you apply volts, amps and materials!
--giantkiller. End of story.
sparks
     I wanted to draw attention to the changes that occur in the circuit due to geometry of the conductor field.  A length of wire bent into a U creates effects quite different than the same length run straight.  I think Neolystic did a damn good job describing the effects.  Superluminal effects.  Hmmmm  So now we have a real problem.   Just from bending the wire.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Neolystic
@Sparks - thanks for your compliment.
@all
Another fascinating property of the dielectric field is that both metallic and non-metallic matter responds to its force. In 1962, Jefimenko did an experiment using grass seed spread over a glass plate to show the dielectric field of a toroid.  See http://www.scielo.br/scielo.php?pid=S0103-97332004000800041&script=sci_arttext , figure 6.  This shows the dielectric field shape of a toroid energized with DC current (ignore the drawn-in lines...look at the grass seeds).  Now if you take that battery (on the left of the picture) and spin it around the toroid, you can visualize how the dielectric field will change in relation the the rest of the toroid.  The effect of a single pulse or sine wave flying around the toroid would be identical.  Now multiply that one pulse by whatever number of pulses are in the wire at any given time, and you can get a picture of what's happening.
Moab
Quote:
This ia grain, Which any fool can eat, But let us give praises to the creator who made it by learning about Beer.  ( Little John )    ;)
Quote from: giantkiller on November 05, 2008, 04:44:24 PM
-Frank Edwards
Azeem: In my dreams alone have I imagined such a place.
Robin Hood: Then imagine a way to cross it.
--Robin Hood
