Deyo Antigravity and fractals
Started by libra_spirit, May 24, 2008, 05:22:35 AM
libra_spirit
Frequency has been a puzzle with torsion fields because they are not exactly linear energy forms.
If you look at a shallow pond, drop a stone in the middle the waves moving outwards shift frequency, that is, as you move outwards the waves tops move closer together until they match the ponds charcteristics. Water depth, distance to sides, etc....
When the wave meets the resonance charactistics of the medium it travels through then it will stablize I believe. Any impulse distrubance will have to eventually match space, or the Aether density. At this point it will still have a multitude of possible sub fractal frequencies present within it. I have not had time yet to even chart this to see if it is a harmony or not. All kinds of speculation that it may come out to a phi function of some kind but I have yet to observe any such phi functions.
The fractal system takes us to infinity, or at least into the conscious arena. The torsion devices thus have side effects on the spiritual parts of our being. But it also allows us to work from any frequency base to stimulate torsion fields, from audio to nuclear resonance rates.
On the Sun fractal rod length:
I just realized that this rod probably needs to be pointing at the sun, or one of its wheel of 24, this will make it much harder to work with.
Also I would mention that Joe Cells often go dead at night, they have a cycle of 6 hours like the tides where they drop twice a day and peak stronger twice a day. We have had one designed now on the golden light fractal of 1.89" the tubes were made to twice this length and the cell has been reaching higher levels of water conditioning and voltage following this daily cycle.
Now this makes more sense because as the moon sets the earth turns under it and shifts the gravity center of the earth accordingly along with all the water on the earth. This proves a connection with the lunar gravitational pull. Amazing!
Dave L
tishatang
Dave
I can not access the link you supplied.  I am in China and behind the China Firewall of info.  Thank goodness overunity and youtube get though.  Although youtube was turned off for about six weeks.  Google video and wikipedia was off for a long while, but currently coming through.  Also, no hardware stores here in China.  Everyone lives in large condo like complexes.  No one has tools to fix anything.  They call the maintenance dept.  Even if I found the supplies, I have no place to experiment.  Sometimes very frustrating.
In regards to your detecting the nodes, are you using your body as the instrument similar to dowsing?  Are there instruments to record the nodes?
I didn't realize the large number of variables until you mentioned it.  Let us focus on the 7.45 cm length and explore some possibilities:
Does a rod seem to have more energy than a flat triangle 7.45 on a side?
What happens if we go three dimensions like a pyramid either of rods or  flat stock?
Have you tried it as an antenna  and measured voltage between it and ground?
Put a tunable tank resonant circuit between the antenna and ground using an old fashion air capacitor out of an old radio.  Slowly sweep the bands and hopefully a resonant point will be reached boosting the voltage way up?
      Example:  http://amasci.com/tesla/tesceive.html
Finally, try to fashion a rod out of bismuth and magnesium.
Tishatang
libra_spirit
http://magnetism.otc.co.nz/ Oz site
http://209.193.33.179/ Alaska site
Here are some mirror sites around the world of our experimental data base, hope you can get one of them over there in China.
Why would you use magnesium? I have not worked with it as of yet.
Yes palming is the method of sensing the torsion fields that is fastest once you are able to sense them. We do have one device now however. I understand over there you have access to some large quatrz crystals. Have you run into any?
If you can get on a site go to "Theory section" then "Measurements section", the one at the top will often give you ability to meter a strong torsion field in metals. You take two high speed doedes into a small capacitor and then to a meter. It only has one sensor pickup rod. Some of the Joe Cell people have been getting it to work well.
The energy has a "propagation" ability, through metals mainly, that we have studied in depth. Angles are criticle, and yes in the platonic shapes it does different things. A 60 degree angle I believe shifts it drastically. The pyramids are a good method to get a loud rod quieted down. A triangle inside a circle converts the energy to power at the chi level. The gold would be to get some EM comming out of a torsion field without having spining wheels or flywheels. As far as I know the connection has not yet been made on exactly how to do this.
Do you have good access to the net there?
Later,
Dave L
tishatang
Hi David
Yes, both these links work for me.  You are into this much more than I realized.
I don't know how much you have looked into the link I gave you.  If you have not had time, go to the following link and eventually read all the free articles there.
http://www.divinecosmos.com/index.php?option=com_content&task=section&id=4&Itemid=30
I guess this could be called David meet David.  To me, both of your works seem to dovetail together.   Although David Wilcock is a psychic, he has a great scientific mind, and these articles are a synthesis of years of research.  I have a feeling little bits of info there could help you in regards to AG and harnessing torsion fields  to meet our energy needs.
The big problem for me here in China is the language barrier.  I don't speak Chinese and my new wife does not speak English.  Interesting relationship,  we have no arguments.  I don't know how I can go about finding crystals?  I did see somewhere some crystal balls, but they did not seem as large as yours.  Nor do I know what they were made of.  Could have been glass for all I know?  Although some were obviously natural, being marbled and yellow in color.  I am in a Northern coastal city which exports mostly industrial supplies.  Not in the center of things like Beijing or Shanghai.  I have an Egyptian friend who speaks both English and Chinese.  I will talk to him about crystals for you.  Did you want crystal balls or natural quartz crystals?
Maybe about ten years ago some metal parts (allegedly from a crashed UFO) were analyzed.   They were made up of thin layers of bismuth and magnesium.
They did not understand how they were made because there was no bonding agent, yet the layers would not separate.  When subjected to high voltage, they flew off the table and across the lab room.  So. there is something special about these two metals in combination.  And, they are related to anti gravity.  Be careful with magnesium, if it gets too hot it will auto ignite and burn in the open air.  I think powdered magnesium is what they make sparklers (fireworks) out of?  Once ignited, you can not put it out.  I don't think this will happen by gently hammering bismuth onto it.
My connection is DSL, but sometimes it slows to a crawl or just dies.  I think it is because everything gets funneled through the China Firewall?
Tishatang
tishatang
David
It came to me that you may find this site interesting.  I can not access it.  It has been several years since I visited it.
Has to do with spherical shapes and resonance and more.
http://coralcastlecode.com/
Tishatang
