Free Energy Revealed - Magnet Battery
Started by 0ne, May 25, 2008, 09:14:52 PM
Jimboot
Ok I am now getting 3.5 volts. I thought there was something wrong with my meter as it was only showing one volt when I turned it up to 20 voila 3.5. when set to 200V~ I get 6. and 80 microamps
Anyone here?
dolomo
Hi Jimboot,
maybe you can post a picture of your setup? I can't get any voltage out if i use something else than moistured paper. With plastic between my readings are zero.
But i get allready over 5 Volts with a serial setup like seen in my previous posts. There is no limit.
Jimboot
Exellent - How do I extract the power? Are you running anything with the volts?
Koen1
Quote from: dolomo on July 05, 2008, 08:38:17 AM
Which proves that it is galvanic! You've got a crude galvanic cell that works due to the humidity in the paper, and does not work
anymore when a real dielectric is used instead of a paper 'electrolyte'.
QuoteBut i get allready over 5 Volts with a serial setup like seen in my previous posts. There is no limit.
True. That's a characteristic of galvanic batteries: you can stack em and increase output.
That's how they get those normal 9V "block" batteries to produce 9 volts: they are often just 9 small 1V cells
hooked together.
Nothing surprising.
What you have is proof that it is not a "magnetic" battery but that it is in fact really a galvanic battery.
And I take the silence in the thread to be confirmation of the fact that the others already figured this out. ;)
0ne
Koen1 stop running your mouth, I already made a video long ago proving its not a galvanic reaction by doing exactly what someone said. I used a trash bag that is made of plastic, with no moisture.
http://www.youtube.com/watch?v=yQHLtSDwtyc
With low amp's from these magnets, trash bags do not work well. That is why you need a different type of dielectric or insulator, or whatever you want to call it in this case.
All I know is, the laws of physics are flawed. Physics doesn't even know what a magnetic field is made of. Tell me, is a magnetic field a wave or a particle?
I know the answer, do you?
