Free Energy Revealed - Magnet Battery
Started by 0ne, May 25, 2008, 09:14:52 PM
Jimboot
I haven't tried with nickel washers yet but with new meters new leads I am getting similar readings with a single washer from the array in a solution with mag and just a washer mag and paper. Looks like a gal battery to me.
triffid
I tried it with a cubic magnet and a keychain(in place of the keeper).I could make the minus sign go away or come back.But could not get voltage readings untill I put some water on the dielectric(cardboard).My voltmeter reads only 1/100 volts not 1/1000 volts.The highest voltage I got was .11 volts.It was easy with the water added to get .05 or .06 volts.I wish my voltmeter could read 1/1000 volts.I would have liked to know what millivolts I could get without the water.Interesting experiment however.I got .11 volts with the most water.However I almost got a reading without water.I could make the minus sign go away almost at will(and come back).Triffid
triffid
That cubic magnet is nickle plated and the keychain is made out of low grade steel.So two different metals.But I almost got a reading without the water.Maybe someone here has a better voltmeter than me?I suspect a voltage in the millivolt range is being generated without water?Maybe use glass as a dielectric?Triffid
Jimboot
I'll  give it a try on my meters tomorrow and report back.
triffid
Twice before in other experiments I had made an unintended battery.I am talking about myself,not One here.So I read back over the thread here.Magnesium and graphite electrodes make a very high powered battery.3.5 volts or more just stuck in wet earth or dry earth like some have claimed.I think a voltmeter that reads millivolts and milliamps should be used for this experiment.Glass is a very good dielectric,So maybe someone here could use a glass slide from a kids microsope kit?Triffid
