Free Energy Revealed - Magnet Battery
Started by 0ne, May 25, 2008, 09:14:52 PM
0ne
Quote from: tinu on May 26, 2008, 11:42:22 AM
It?s hard to see the simple real facts, isn?t it?
What, like the fact that everything is electromagnetic? Actually I think you are the only one that can't see the facts.
1. You place instead of the poor piece of paper (which ALWAYS contains moisture, in case I wasn?t clear enough above) a tiny sheet of real dielectric, like the cheapest one taken from a plastic garbage bag or similar. Then you?re welcome to come back and show me the voltage if you?ll ever get any.
I tried two different types of trash bags. One was black in color by some off brand, and another was white in color by "Hefty". I got at least 3mV from Each bag. This is compared to an absolute ZERO reading when no dielectric is used. The conclusion is, even with dielectrics that were designed with high amperage's in mind, it STILL worked. I still think its best to stick with dielectrics that work differently at different amperages, thanks.
I have studied several different types of capacitors, I'm pretty sure I made that clear. I have SEVERAL new capacitor designes that work with sacred geometry, completely replacing any need for a dielectric. Did I mention I study Alchemy and Chemistry as well? Trust me when I say my knowledge is different than yours.
2. Forget about magnets for a while;
Ok, let me just forget about the magnets that are needed at the powerplant to pump the "electricity" I need to run my computer.... Oh and every electric device in the world.
put back the paper you regularly use, place instead of magnet and holder two pieces of dissimilar metals (i.e. cooper and zinc or alluminium) and ADD MECHANICAL PRESSURE (That?s all your magnet does: it attracts the holder and create close contact through pressure). How do you explain the voltage now? It must be a well intricate ?magnetic current? since it manifests without magnets, isn?t it?
Dear child, you need to open your eyes. Everything is magnetic. Yes, if you would have come out from under your rock you would know it is a scientific fact the entire universe is made of electromagnetic forces... That means everything is magnetic. That is probably why you can rub every single object in the world with another object, and get "attraction and repulsion". Yes, static electricity does that. Why on Earth would paper scraps fly towards a magic wond that was rubbed with cloth? Why do lightning bolts leave my fingers after rubbing my feet on the carpet? Am I a magnet? Is the carpet a magnet? Yes. Everything is a magnet, that is why everything can make "electricity". Even if it's "static".
Do you understand the TRUE NATURE of MECHANICAL PRESSURE? Where did that pressure come from? Other magnets? Yes. What is it really? Its strong attraction/repulsion from two objects on a sub-atomic level. Do you know much about quantum physics? Maybe I should refer to you the fact that a basketball, when bounced on the ground, NEVER TOUCHES THE GROUND. Read about THAT.
3. I?ve read several papers of Edward Leedskalnin. For his time, the man had a few ideas. Rudimentary ideas and concepts, nonetheless but at least he tried. For our time, it?s plain BS. None of his devices work. What?s the point?
You CLEARLY missed ALL of his SCEINTIFIC EXPERIMENTS. His entire "Magnetic Current" book is full of PHYSICAL EXPERIMENTS.
You also missed when he said this:
"The reading is not intended for the general public. Only those who want to experiment should order the booklet. The other people should save their money."
Also, his "perpetual motion device" worked flawlessly as he claims. It's a perpetual motion device (invisible to the human eye motion), its a power transformer, and it is an electromagnet. 100% worked flawlessly.
0ne
Quote from: capthook on May 26, 2008, 12:13:20 PM
Well, more magnetism requires more size.......(where to get an N5,000 magnet? )
And as to practicality - if a device doesn't do anything useful (ie. create useable power at a reasonable size)- what's the point?
capthook, you can make your own magnets with "electricity". Read Ed's book and you will know how.
Also, I assure you, size is not an issue. Please stop looking at my device as a product, look at is as a method. This method CAN be improved. Actually, I'm quite sure that this Magnet Battery method holds the key to collecting energy from Earth, wirelessly. Just like Nikola Teslas black box.  You only need to understand the true nature of the universe and the true working method of this Magnet Battery to understand.
Nikola Tesla powered an electric car to 90mph, and said it would never stop running. Do you understand how Earth can allow you to do that? I'm pretty sure I do.
wings
fast test:
best results 25mv with cotton tissue 2 layer better than 1 and stone drill bits on the other
side.
low value with iron plate.
If you put an intermediate aluminium iron or bronze plate and meausure
voltage between this plate and the magnet low value less then 5mv.
This mean that the effect is not capacitive.
The voltage is stable.
tinu
@0ne,
Well yes, you are a smart alchemist. I?m just a poor physicist...  ;) LOL
Why on Heaven would an alchemist try teaching a physicist quantum physics?!   ::)
Or even mention it?!  ;D
Quote from: 0ne on May 26, 2008, 12:36:31 PM
This is not holding water. Maybe some will buy it but that?s not me. I suppose you don?t have a movie proving it, do you?
Now that you prove your superiority, can you just take off the donation request on your scientific web page?
Cheers,
Tinu
barbosi
[snip]
I used to be a great admirer of Ed.L.
Not diminishing any of his accomplishments, or his determination, all I can say Ed was a fervent reader of technical/scientific literature. Having said that, all his accomplishments were based on information from text books.
The way he put all this information at work might be [or not] entirely his achievement.
As for "None of his devices work" here I have to strongly disagree.
His PMH is a single example. The principle is from a book of his time (not his invention) and since then, not many dared to build his PMH.
However here it is at work:
http://www.youtube.com/watch?v=Y31dUcO2z_o
And Tinu, please don't take me offensive, out there is a great deal of examples which prove actually that current science is the brainwasher. Otherwise PMH would be common knowledge nowadays, not fiercely dismissed as BS.
Again: http://www.youtube.com/watch?v=Y31dUcO2z_o
or DIY if there are money to spare.
Regards.
When the Power of Love overcomes the Love of Power, there will be peace.
