Free Energy Revealed - Magnet Battery
Started by 0ne, May 25, 2008, 09:14:52 PM
0ne
Listen, the bigger the mass, the more electrons you can draw from it. Once you draw electrons from an object, their protons automaticaly find new electrons that circulate all around us, especialy from EARTH!!!!!! But don't call them those terms! Forget everything you learned! Everything is negitive and positive charges. You can build up 0ne or the 0ther.
Tesla showed ALL, powering his lightbulb to the ground, the EARTH IS 0NE!
ALL IS 0NE
The Egyptian Lightbulb:
http://www.secrets.rodinsquarters.com/egyptiandc.jpg
It's like a Voltaic Pile connected to Earth, with a spark gap!!!!!!!
http://en.wikipedia.org/wiki/Voltaic_pile
LOOP IT!
0ne
0ne
Using a cone shaped piece of metal or a pyramid piece of metal, you can BUILD CHARGE!!!
It's litterally like forcing this stuff through a small nozzle!!!
repulsion ... small to big = amp
repulsion ... big to small = resistor
attraction ... small to big = resist
attraction ... big to small = amp
Get a square magnet, put it in iron fillings. The fillings will be attracted to the EDGE, because the V type edge. They are all trying to squeeze out a small nozzle.
crash_uni8
i like your idea of using a magnet as a battery,but your magnet battery to me is nothing more than the reaction between the steel/metal plate and the nickel coating of the neo magnet and using water as the electrolyte or dielectric. if you replace the magnet with a different metal than nickel you get a much higher voltage...
