Free Energy Revealed - Magnet Battery
Started by 0ne, May 25, 2008, 09:14:52 PM
0ne
Hello All!
I have decided to release some information to change the world. I am doing this 100% free of charge. If the information I give you is helpfull in any way, which I'm sure it will be, feel free to thank me with a donation on my main web page.
If you have any questions, you can ask me here, or on my forum.
So here it is, the Magnet Battery:
http://www.lawofmagnetism.com/magbat.html
TheOne
I tried with 3 cylinders magnet with 2 dispositions, one with the U and one with I with metal plate but that give me nothing, I only get some voltage when I touch the probe but nothing from the magnet, I was using neo magnets, maybe neo is not appropriate for this kind of experimentation
0ne
No, all magnets work. What dielectric did you use? And did you use a metal plate? Or just magnets? Also, the best readings are in D.C. mode.
TheOne
A piece of paper (0.05 canadien tire dollar lol)
and the metal was a tiny sheet strapping piece, but my magnet are not U shaped
its only cylinder so to form the U i used 3 like this [_].
0ne
Ok, don't try to make a U with multiple magnets, it doesn't work like that. Each one of those magnets has its own circulation. When you mix 3 different circulations together, you don't get the same effect. A real U magnet has 1 circulation.
If you want to test this battery without a U magnet, just use 1 magnet, 1 dielectric, and 1 piece of metal. Here is an axample I made for you:
Its a sphere neo super magnet, piece of paper towel, and the magnet is sitting in the middle of a metal washer. Its getting .141 Volts!!!
The only reason I display a U magnet setup is because it makes it stronger, and makes it last longer. It's my own design to also concentrate the magnetism more into the dielectric instead of scattered around.
