Has anyone on this forum actually made a device that runs off of pure HHO?
Started by Intangion, May 28, 2008, 03:48:14 PM
22350
Quote from: Sprocket on June 01, 2008, 10:58:43 AM
Daniel Dingle did so more than 30 years ago.  When he took his invention to the filipino government then, he was told that loan agreements that the Phillipines had procured via the International Monetary Fund (IMF) stipulated that no technology that would threaten the oil cartels could be developed or exported.  So a car running purely on water has definitely been done.  Here is a new link (to me) I just googled - it would appear he has got tired of waiting and is collaborating with others to some extent:
http://www.dinglefoundation.com/
As for Stanley Meyers buggy, though it ran on water, I read somewhere that it probably wasn't your typical HHO setup, more a plasma sparkplug sort of thing.
Which brings to mind another american inventor engineer whose name I can't remember.  Quite a long time ago, he patented a sparkplug/injector that used just water, but when he tried to have it developed, he quickly realised it wasn't going to happen.  He had to contend with being 'allowed' to drive his water-only car right up until he died of natural causes - it's on Youtube somewhere.
So, quite a few water-only conversions have been done...
thanks for the links.
none of the contact links on dinglefoundation.com work.  I wonder if this guy is just snake oil?
Yes, Mr. Meyer's system looked like some sort of injectoion system.
I guess my question is:  Where did the the buggy go?  Where did that assistant, the one in his buggy video, go?  What was that guy's name?
Stanley Meyer died, but did his work disintegrate?
Paul
Sprocket
Quote from: 22350 on June 01, 2008, 02:41:54 PM
Paul
I posted the link more for the inbedded video, didn't check any of the links.  I think there's little doubt that DD is the real-deal.
Stan Meyers buggy and everything else of value were proported to have been spirited off by unknown individuals - just as happened with Tesla!  As for the assistant, don't know but maybe it was his brother - he moved to Canada and has set up a company called Xogen which is based on Stans work...
daveedoo
You just gotta keep on messin around with it and see what works best. I think distilled water definitely helps produce more hydrogen at lower amps and temperature. Too much baking soda doesn't help. Like a teaspoon per liter? Right now I have three stainless steel pipes in four inch i/d pvc. The pipes are four and a half inches tall. One is 3/4" connected to the negative of a 12v battery. A 1" pipe as a neutral, and 1 1/2" pipe connected to the positive terminal. Kinda like the Joe Cell. This or next week I'll be starting over with a plastic box for easier access. I'm going to try plates instead of pipes, and mess around with the amount of plates used, the spacing between them, the amount of neutrals, negatives, positives, voltages(120volts a/c drew more than 15 amps, I tried this weekend) And go from there.
22350
Quote from: Sprocket on June 01, 2008, 09:16:03 PM
Wow, very interesting.
Seems strange that no one could shoe horn this technology out of dingle in all of these years.
When you look at the video of dingle's unit, he mentions something strange.
There are two tubes sticking out of the top of the box.  He mentions hydrogen, when pointing at one and oxygen, when pointing at the other.
I understand, and correct me if I am wrong, but you get a much more volatile explosion, when mixing the two gases.
The set ups I see here put out a single gas, correct?
I wonder where he is now.  Can't find anything on the internet and his domain leads back to a technical contact in Europe.
p
daveedoo
Let's go to the Phillipines, find Dingeldor and tell him he might as well just give away his findings and save all humanity.  :D
