Bendini motor to run itself
Started by chuckage, May 29, 2008, 09:23:50 AM
guruji
HI Mark yes there are people here who build the multi coil if you browse the forum there are schematics too.
I am trying to build one myself and to use it's work force to turn an alternator but still in the process right now.
Ok get ready for work then. :)
Mark69
Guruji,
Ohhh I like that idea!   :o
If you have a link on the multi coil bedini, please post, otherwise ill have to get my lazy fingers to do some searching.
Mark
Goat
Hey guys
@ guruji & Mark69
For a multi coil setup go to page 31 of the document here http://www.panaceauniversity.org/John%20Bedini%20Technology.pdf
Lots of information, both informational and technical (schematics).
Regards,
Paul
Mark69
SteveOll
Quote from: Mark69 on December 20, 2008, 12:05:24 PM
Hi Gurji,
The power inverter I can get easily enough.  Has someone built a multi coil bedini yet?  If yes, I would really like to see plans so I can try and build myself one.  I am a novice when it comes to electricity, so everything would need to be spelled out so I can understand it, as simple as possible with lots of pictures! :D  How many batteries do you think it would need?  That is the step I was trying to eliminate, the batteries.
Mark
I have built the solid state bedini charger. Now it usually outputs over 200VDC which is far too much for a 'normal' inverter (12 / 24 VDC input)
Wouldn't it be better to try to design something that could self-power and output 12VDC at enough amps to power an inverter?
