Harnessed Natural Energy
Started by SINEWAVE, May 29, 2008, 02:02:48 PM
As far as I know the stickypoiny only arises with discontinuities. So if you have indeed a rail a circular rail (like for instance the water wheel here at the left). You could make the magnets in the middle make loops for quite some time. Or differently you can make the cart or w/e static and let the whole rail rotate benieth it rotate.
nothere2win
"Thought people might be interested in what I consider a minor breakthrough in concocting a linear field that may mimic Howard Johnson's toy race car effect. It's based on my original discovery of the three basic spin domains in a single magnet.
For far too long I've thought that all three domains, that I've labeled, A, B, and C must be present in an overt sense to make the thing work, but recently I tripped and fell into what should have been obvious; that A and B as I've defined them in Golden Vortex are the only domains that need be overtly, or three-dimensionally used.
Follow the diagrams below and the "armature" when it moves into the track field does so because of the straight A domain. It then hits the longer B domain and is converted into C. At the end it is reconverted to A and is kicked out of the field.
It enters and leaves the field not because of a magical polarity change, but because of a spin switch, CCW to CW.
In illustration 1, I show a top and side view of a single magnet of any diameter (call it one inch across and one-quarter inch thick). Mark the diameter into equal sections of one-sixth. What is important here is the 0ne-sixth measurement (blue) AND the one-half measurement (red).
Illustration 2 are top and bottom views of six single magnets laid out in a row on an iron or steel plate. The blue space between the first two magnets from left to right represents a 1/6th space, and next three red spaces are 1/2, or the radius of any single magnet apart. The last blue space is again 1/6th.
A single "armature" magnet placed at 90 degrees to the row will, at a certain height, be pulled into the track along the 1/2-spaced center magnets, and then be expelled out the other end. It should be noted that the 1/2 spaced magnets may be as many as you please, 3 or 3000.
In the case shown North travels toward North. To do a simple test as depicted, tape a disk armature magnet to the bottom of a nonferrous stick that is at least six inches long in order to avoid your hand coming within 4.5 inches of the track (I've also recently learned that 4.5 inches is the usual distance in which the human stays in the circuit ... but another story).
Hold the stick at the end opposite from the magnet and test for the right height by pushing the stick and magnet gently against the field while raising it. At a point about the radius of the armature magnet it ought to invade the track field as if being pulled, and then "drag" your hand with it.
Remember, you are stronger than the magnets, so ... go with whatever the magnets "want" to do. Try a toy car?
I'm working on bending the track in a circle and adding armature magnets. A few more tests..."
SINEWAVE
Quote from: PwrDream on May 30, 2008, 12:02:42 PM
If you've really found a way to generate perpetual motion with magnets, you should immediately build a prototype that generates power (say enough to light a few LED's) and get it patented immediately as a toy.  Don't disclose it as a perpetual motion machine, instead, pitch the patent as a science toy to show how power can be generated from spinning magnets.  Of course, take your device to a patent attorney and show the working model to him, then release the simple plans to the public (A Patent  will allow anyone to build your item for personal use, just not for mass production/resale without your permission/agreement).
If financial security or money are not an issue to you, you should immediately disclose your finding to the world on a public platform (show your working device to the media, and create a website that gives away the information to the public).
A person that comes up with a permanent magnet motor that is easy to build, and then releases this knowledge to the public, will go down in the history books....
If you've really done this, do you realize what you have your hands on?  The biggest topic around the world is the energy crisis, and you've solved it by coming up with a method of building a generator that can power your house, your car, ... everthing....
Do the right thing with this knowledge now if you have it, otherwise go away .....
when i made my discovery "Change the World" by Eric Clapton came on the radio...then later on that evening, the ceiling light in my livingroom started flickering and went out....
when i was young and lost faith in god i begged him for evidence that he was real...the next day the light in the hallway went out, in the same way.
i am not a religious nut or do i even go to church...but these two occurrances made all the hairs on my body stand on end...for the past few days i have been experiencing a very strange sense of fear like someone is observing me.
my request for magnet pictures will simply be evidence that can be used to debunk naysayers and big oil reps employed to downplay the proliferation of self sustaining energy.
this simple machine is so cheap to produce literally anyone can make it , there is absolutely no profit involved with these machines...that is how cheap they are to make...if you are looking for a lifetime of usage (considering the mags dont wear down)
which brings me to my next point involving those who choose to ask for donatins to fund their projects...a true scientist/inventor will have purchsed all types of magnetic geometries to test with....at this point they will have placed all possible positions, with every possible variation in tolerances they could think of....and at the least would have been able to achieve forward motion....it does not take thousands or miliions to accomplish...it took me $50 to obtain linear travel through a space of 1 yard.
with a speed of approximately a 1/2 second...
anyone asking for donations or funding is a conman period...but those who ask for a one time payment for transfer of intellectal property rights are probably legitimate.
from a business standpoint, no business would ever sell a machine for $100 when it can be used for life...within a persons lifetime can you imagine how much money that person would save? and without a gradual adjustment in world economies, do you realize what kind of damage that would cause?
electricity cost for residential housing with a family of 4, with ac running 24/7 , that would be...$500 per month= $6000 per year x lifespan of 50 years =$300,000 and this isnt including gas for your car...
now muitply that number times the general bill paying population = lets just say 20 million people = $6,000,000,000,000 and this is just for one country.
where will they spend the excess money?
how can we change the world economy and make it benefitial with the divertion of funds?...free energy isnt the problem, its how to implement it...the nobel prize wont be won by the person who develops a free energy machine, hell thats been done MANY times, in many different forms, my way is just a different variation....it will be won by the person who can implement it...
btw im glad Haliburton and Broli have finally decided to get their heads right....i cant imagine a tree hugger who would speak to their fellow man in the manner in which they have exhibited...this doesnt really show a genuine compassion for human kind....rather it shows why 'some' humans are not ready for this technology.
bw
this guy is right to some extent, we should all experiment and forget everything that says it cannot work, but i also do not have time for a lot of games and i would have to spend time i don't have to send photos.  i flipped a skateboard upside down, taped two neos on one of the wheels with oppisite poles facing out and by holding a third bar magnet along the center line of the wheel magnets can spin the hell out of the wheel with the slightest movement of the thin bar magnet.  when the right rythm or resonance is realized it fees like a fluid movement almost effortless.  i taped different configurations of magnets to a stick to drive the wheel and have found many that work well, a slight angle seems best with poles facing left and right  or horizontal if wheel is vertical.  i fastened the stick to my bench with a nail to hinge the pivot point and again the slighest movement of the stick makes the wheel spin.  play with that, feel the power and rythm, it almost floats, seems to want to keep moving.  then design a linkage to the wheel to time the movements of the stick and your skateboard wheel should spin till the bearings fall out.  now, i shared, see how easy that was..i even feel better now.
SINEWAVE
why does thou hast not the time? (sorry just had to)
what' the rush?...it takes 5 minues to send a photo...
i use to skate..."Rodeo" blows me away...i got out around the time the 540 and Mc Twist came out....all my friends were breaking bones, so i went into motocross instead...go figure.
too much reliance on mathematical models...
dont be shy to post pics even if you have less than 10 mags, it takes less than that to prove my discovery.
