Perpetual motion and gravity
Started by mapsrg, May 31, 2008, 11:30:47 PM
mapsrg
When gravity is used as a means of causing rotation of an unbalanced wheel people start talking about getting something from nothing..........since gravity is a continuous effect isnt it a valid input energy source?
Onevoice
Personally, I think it can be. The problem with any of these gravity wheels or magnetic motors is one of symmetry. Gain a little but then loose a little. In the end, there is no net gain. In order for something to demonstrate an excess of energy, it must be constructed in such a way that symmetry is not maintained, gain a little, loose a little less. I think it can be done. If multiple forces (IE gravity and magnetic attraction) are used and if a path can be plotted that requires less energy out than in. - At least thats my theory.
quote: The needs of the one outweigh the needs of the many - Capt. James T. Kirk
Justin
You dont have to constrict the creation of perpetual motion through simply gravity and magnetic fields , wouldnt it also be possible to  use other forces such as buoyancy.
greendoor
I don't believe anyone really knows conclusively what gravity is.  There are many theories, but they are still just theories.  I don't believe anyone can conclusively say whether it is a monopole or a dipole force.  The observable effect that all objects in earths gravity field are accelerated at the same rate - regardless of mass - is an important observation that bears pondering on ... is gravity is a dipole - a bit like a "river" of energy -  and anything flowing in that river gets accelerated up to the same speed and can't exceed it? ... if gravity was a monopole attraction, shouldn't the speed just keep on increasing the closer the masses get to each other?
A big factor in how we view gravity is whether we believe that space is an empty vacuum with mass dispersed throughout it - or is space comprised of a real but invisible material (lets call it aether), and mass is like bubbles or standing waves in this material?  The great electromagnetic scientists who gave us electric power all tended to believe in aether.  It makes good sense: electromagnetic waves have to "wave" something - otherwise they aren't "waves".  There are good reasons to believe that Einstein A/ wasn't the originator of his key concepts, and B/ set science back 100 years by pushing certain wrong concepts.
Personally - I tend to view gravity as a flowing river of aether.  Aether has no mass - but mass is created out of aether.  Aether flows like a fluid - highly complex movements.  Study things such as the "Aspden Effect" or "Casimir Effect" to get some clues as to why I believe this should be considered as true science.  As for the Michelson Morley experiment which "proved" the aether doesn't exist - that is either deliberate fraud or very bad science.  All it proved is that there is little or no velocity difference between earths rotation and the aether they were looking for.  If you believe that the earth is completely embedded in the aether, and in fact each particle composed out of aether, then obviously the aether will be rotating at exactly the same speed as the earth too - no speed difference will be detected.  Bad assumptions leading to stupid conclusions (or deliberate fraud used to hide important truths).
greendoor
Anyhoo - if you view gravity as being a river of energy flow down around us - is there any possible way we could use it to send mass upwards, "against the stream"?
It's obviously difficult - which is why nobody has appeared to have succeeded.  Although Bessler in the 1700's appeared to have found a way ...
Yachts can tack against the wind and use the power of a prevailing wind to go in the direction they want to go - even into the wind.  This is a clue as to how we would have to use gravity to go against gravity.
Imagine a boat or vehicle powered by a couple of counter-rotating Savonius Rotors.  (These are the split-offset vertical-drum-type windmills.  A Savonius Rotor is self starting, self regulating - and produces good torque at low speed from wind in any direction .  It should be possible to design a vehicle that can be driven into the wind, powered by the wind ... think about that and then think about gravity wheels again ...
