gas but no savings....... HELP
Started by mrmechanical, June 06, 2008, 08:12:02 PM
Creativity
Normal way to lean out carburator is to lower the gasoline chamber level or rejet the carb.As said above,HHO won't make any difference if it is in very small quantities(what is small u can read in other posts in this section).U may see some difference at the idle as exxcomm0n said,lean out a bit at idle by turning idle mixture adjusting screw 1/8 turn in(clock wise).
Blues it through your outstanding life,leaving more than just footsteps behind (1999 B-stok by me).
By being intensively responsive to what others say,i do run a risk: I open myself up to the opinions of others.i will,at times, have a great understanding for their opinion.Sometimes,i will even change my own opinion because i realize that the other person is right.This "risk" i do not run if i am unresponsive to what others say.
mrmechanical
Thanks to everyone for all your input so far, here's a little more background. The car is a 87 nissan Sentra. It has a feedback carb, that takes most of it's input from the oxygen sensor, there's a fuel enrichment solenoid in the carb that controls the mixture, I read the haynes manual on the car and found a way to disconnect it, so the oxygen sensor can do whatever, the carb cannot change anything. Bad news is that because of the type of carb, the only adjustment possible is the idle mixture, but that is covered by a plug I have to remove, everything else is set at the factory, I can put a webber on it, but don't want to, although a webber is adjustable. My current theory is that I was losing my gas, so I checked and resealed the bubbler, and put vacum to it (1 inch at the generator) that I didn't have before. I noticed that since I did that the idle is up about 150 rpm. More to come.
God give me the serenity to accept things which cannot be changed;
Give me courage to change things which must be changed;
And the wisdom to distinguish one from the other
vdubdipr
cool cool....  "leeme seeya bounce right to left and let your engine lean just let your engine lean" rick ross... miayo
thats just what i think...
Chucky
hi there, im batling please help. i have build a hho elecrtolizer, i'm using ss plate's would a pwm work with te plates or does it only work with the ss tubes.
when i conect the pwm with te ss plate system I build the currant drops, but the gas progution drops like hell aswell.
the pwm is the one on pdf 14,
Chucky
hi there. in new please be kind.  i,m not a expert, but some day i wane be an expert on this.
ive build a electrolizer and want to know what exatly what is the efect on a hho cell with a pwm.
i have conectet a pwm to my cell. the curant drops but the gas prodution drops aswell, any ideas
