URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
Groundloop
Luc,
Attached is the same simple circuit with external trigger input.
Note: Adjust the SCR trigger voltage BEFORE switching on circuit.
This circuit can be used with external trigger in an engine enviroment.
Groundloop.
gotoluc
Quote from: Groundloop on August 24, 2008, 02:35:29 AM
Luc,
Here is a proposed very simple circuit for testing on your system.
The circuit works like this:
The 120 VAC is rectifyed through a diode bridge resulting in only positive pulses after the
bridge. The capacitor will charge up and when the capacitor voltage reach approx. 120 VDC
the Neon bulb will light sending a small current to the SCR trigger. The SCR will then dump
the capacitor charge into the ignition coil. The BY diode is there for back emf protection. The
5 watt resistor is a current limiter so that the SCR will survive.
Groundloop.
Wow :D Groundloop,
thank you for all the great work you have done ;D  I can see that this is a very simple circuit which those with no or little EE will be able to build, including me ;D
Excellent work ;)  Thanks for sharing.
I will also share your circuit at the Energetic Forum...I hope that is okay with you?
Luc
gotoluc
Quote from: nul-points on August 24, 2008, 04:15:54 AM
hi Luc
[Edit: i said i'd get back to you with an update on the SS mods you were looking to replace the relay with in your existing circuit - as i'm about to post this i see Groundloop has just posted an SCR-based schematic, so my suggestions may be redundant now but i'll post anyway in case you also decide to try your existing circuit with SS mods at any time]
i've updated my previous schematic to show how the solid state SPDT switch arrangement which Groundloop adapted for you
    (http://www.overunity.com/index.php/topic,5438.msg122802.html#msg122802
in your SS SPDT thread could be modified to split the switch into two and move your inductor between them
this would then enable you to use D2 to reclaim the flyback energy from the inductor into your 6u8F capacitor (C2) to boost the discharge as i was suggesting earlier
i've left the suggested bridge cap (C1) in place - this would give you maximum input charge to the 6u8F every strike
if you use R1 to protect C1 from damage due to in-rush current, try with 220R initially & vary C1 to the minimum capacitor value which still maximises charge volts on your 6u8F at your required strike rate
D3 is suggested to provide some protection to MOSFET Q2 from any flyback voltage from primary of T1 - if there's no significant flyback there, remove D3
(D2, D3 can be 1N400x type)
the source circuit which Groundloop adapted for you didn't seem to have any protection against overlap of switching voltages (to ensure that both outputs are not 'on' at same time) - might not be an issue depending on the actual switching signal circuit used, but suggest you check Q1 & Q2 gate drive signals on 2 channel scope (with no AC to Bridge), before allowing the FETs to switch real charge from bridge to transformer!
i think you could test this circuit arrangement below with a DPDT relay (as long as you've got 'break-before-make' contacts!) in place of the MOSFETS - in which case certainly include D3 (in addition to D2) to prolong relay switch contacts
all the best
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
Wow :D also excellent work on your part Sandy!
thank you for taking all this extra time to help the project!... you guys are God sends. Many have been asking me for a SS switching and I think now we have some good and simple stuff to share.
I will also share this with the Energetic Forum, I hope that is fine with you Sandy?
Once again, thanks and God Bless
Luc
turbo
hey men i tried to post over there but i can't.
dunno what's happening..
M.
gotoluc
Quote from: -[marco]- on August 24, 2008, 12:45:07 PM
M.
Hi Marco, are you referring to the Energetic Forum?...if so, after you apply for membership you will not be able to post until they send you an approval of your application. Unfortunately it's not an instantaneous approval system like here at OU. If you need help to speed up the approval send me a PM.
Luc
