URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
gotoluc
Excellent repair solution Greg ;D
Thanks for taking the time to post all the pictures of the repair ;)
Looking forward to the 2009 tests using the new HV Power supply and the Firestorm style plugs.
Thanks for sharing
Luc
djzissis
Quote from: gmeast on January 02, 2009, 05:07:15 PM
Happy New Year everyone,
The Bug is whole again ... finally!  I will be reinstalling the VexUs circuit with its new oscillator.  Also I have begun documenting the physical dimensions of the firestorm spark plugs so that I can detect any wear.  I'll post the photos and other data both on Energetic and OverUnity.
The oil leak 'fix' was challenging just because.  What I did seemed to work though.
I know it's off topic but I posted some pics of the task:
Peace,
Greg
oil cooler ready to remove
http://home.pacbell.net/gmeast/VW/cooler0.jpg
broken mounting tab still on cooler
http://home.pacbell.net/gmeast/VW/cooler1.jpg
tab and block
http://home.pacbell.net/gmeast/VW/cooler2.jpg
cut off remaining (old original) mounting tab
http://home.pacbell.net/gmeast/VW/cooler8.jpg
fix-it mounting plate
http://home.pacbell.net/gmeast/VW/cooler3.jpg
screw heads for metal filled epoxy to grab on to
http://home.pacbell.net/gmeast/VW/cooler4.jpg
fix-it plate mounted ... see the screw heads
http://home.pacbell.net/gmeast/VW/cooler5.jpg
metal filled epoxy stuffed into damaged area
http://home.pacbell.net/gmeast/VW/cooler6.jpg
epoxy filed and cleared for cooler mounting stud and nut
http://home.pacbell.net/gmeast/VW/cooler7.jpg
ta da  done and ready for cooler and seals, shroud, alternator, distributor, carburetor ... whew!
http://home.pacbell.net/gmeast/VW/cooler9.jpg
Hello Greg!!
Excellent work.! well done.!
I really like it. I also love this boxer engine too..!!
Nice results..... The bug is back!!
Keep on for the oscillator and the plugs.
Thanks for sharing
Zissis
djzissis
Hello every one...!!
I am really very happy today because,
I have just purchased the small yellow lady, just to test plasma (VeXus)!!!!
Here I have the photos, take a look.:
Photo No 1
Photo No 2
Photo No 3
Photo No 4 (the sparkplug is down there....)
Engine Description I found on the internet:
Model  A168F-1
Certificates  EPA, ISO:9001:2000 passed
Type: Single cylinder, 4-stroke air-cooled, OHV, gasoline engine
Bore x stroke(mm x mm): 68x54
Displacement(ml): 196
Compression ratio: 8.5:1
Rated output power(HP/rpm): 5.7/3600
Max output power(HP/rpm): 6.5/4000
Max torque(N-m/rpm): 13.2/2500
Ignition system: T.C.I
Spark plug: E6TC
Fuel type: Unlead gasoline
Fuel tank capacity(L): 3.6
Fuel consumption(g/KW/h): 400
Oil capacity(L): 0.6
Lube oil type  SAE 15W-40SE or higher
Starting system: Recoil starter
Speed adjusting mode: Centrifugal weight mode
Lubricating mode: Splashing
Air cleaner: Semi-dry, Oil bath, Dual, Silent, Cyclone
Overall dimension(LxWxH)(mm): 395x340x360
Net weight(kgs): 15
Gross weight(kgs): 16
20FT volume  594
40FT volume  1200
So what about ignition now....
Take a look at those pictures.:
http://farm4.static.flickr.com/3079/3162170779_7edd3c9a86_b.jpg
http://farm4.static.flickr.com/3085/3163005522_e54d662616_b.jpg
It says that it has T.C.I. ignition.
If someone knows anything about this kind I would appreciate it if he could help. We want to get 12volt pulses from somewhere in order to trigger a transistor (TIP 122) and then an external automotive coil.
There is some voltage 1-2 volts between black and yellow(earth) cables when i pull the rope.... but i think that this couldn't offer something.
Thats all for now,
Updates to come.....
Thanks,
Zissis
P.S.: Everybody, this small engine needs a name.... What is your propose??
b0rg13
if you want to get out of the rat race,you have to let go of the cheese.
Damianos
First of all,
I wish you a happy new year ,my friends...
Hi Zisis,
Very good engine!
I think Sparky is also
a good name for her...
Thanks
Damainos
