URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
gotoluc
Here is what theWIKWIPmaker has written about his sparkplug design
Luc
theWIKWIPmaker  |   August 19, 2010
OK, now I want to give to Mankind a great Present!
Now I give you all my Input without any return!
The majority of you are using still a damned Spark Plug. Why? Every video show the same problem. I see always a mist between the electrodes or water film on them. And al the spark plugs are arranged horizontal on tables or turned with the electrodes to the sky. Some of you had the idea to conduct some vapour to the Gap. Forget these pleas! It is the wrong way!
I recognized immediately that this is your main problem.
Now listen to me! Forget al spark plugs and create a totally new one!
If you want to hold water on or between the electrodes you should use a sponge! I solved with my WIK-WIP a second problem that you al have with your spark plugs still our days. My WIK-WIP can conduct through the plus electrode water and will charge the tungsten sponge after each ionisation immediately with water. As you can se in the video, I have no Tungsten-Sponge.
The problem is nobody can buy the tungsten filter. They are still not produced! And therefore nobody have a chance to make experiments with them.
I think we can convince some special companies who work with tungsten to start a mass production for us. A sponge of tungsten will be better. But there can be also a problem with them too. Tungsten will react with hot oxygen to tungsten three oxide and will not live too long as we want. I don't know! I hope the water from the inside will cool the heating area. We can also protect the surface of the tungsten sponge by galvanizing them with platinum.
The Discharge works with:
-massive avalanche of ionisation
-UV-arrays from the Plasma
-separation of water by 1700°C
It's a electrolysis, photolysis, thermolysis.
The metal sponge made of tungsten, suck the water through his body and hold it still the ionisation start.
Between the sponge and the mass electrode the current start to flow and the water begins to evaporate caused by the rapid increasing temperature. The great part of the sponge is now shooting by very fast electrons that come from the big discharging. The electrons create a massive avalanche of ionisation to the water molecules. In this avalanche are appearing a lot of hydrogen and oxygen atoms and also "damaged" Water molecules. They are not really damaged but they lose some electrons. So they get radical. At the same time appears the plasma with the UV arrays which is now shooting again to the water molecules and to the radicals. At the same time the area gets hotter then 1700°C. At this temperature the water molecules will separate also in H² and O². Now the mixture reaches a critical point because there are a lot of Hydrogen and Oxygen in it. Suddenly it starts to burn. It burns very fast and causes a big explosive pressure. The surface of the sponge is now nearly free from water. But the water flow immediately from the inside to the surface and file it up. And the next tact can start again.
I don't know which circuit is the best and more efficient to run the WIK-WIP. I'm not expert!
But there is one think that everybody should think abut:
The WIK-WIP needs a great discharge to create a good ionization and to produce great plasmas.
Only the ionisation of water in combination with the plasma produces the pressure which we need for our engines and nothing else!
I think the Water as Fuel-Technology will change the world.
It will create a world without pollution and poverty!
Pleas continue this good work!
Many Thanks to capacitor70, s1r9a9m9, gotoluc, glotoniok and all the other good man!
gotoluc
Hi all,
this maybe of interest: YouTube - Geet Pantone Engine Concept Demo by Andreas Kalcker
It is basically the GEET design but no rod and magnetization stuff. I believe Andreas Kalcker  has it right.
Please have a look and post your comments
Luc
Added: He explains it well at 6.55 min. in the video.
Here is his YouTube Channel: http://www.youtube.com/user/aluka1603?blend=2&ob=1#p/u
MasterPlaster
forest
Quote from: MasterPlaster on August 26, 2010, 08:00:56 AM
But the video is only 2:58 long!?
and at 2.59 he is saying interesting things about polarization process. Incdredible !  :P
gmeast
Hi,
I, also, am trying to find the video he speaks of.
