URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
xilusma
@Gary and all,
The DC and HV-AC are not directly connected. He just used the HV for the bridge (arcing) before pulsing the DC. Just like Luc circuit (if I may say so) or any other arc welding circuit.
Regards,
p/s: I think there are similarity if not direct understanding of how the TPU's work.
use energy wisely - dare to dream
resonanceman
Quote from: xilusma on July 03, 2008, 02:30:27 AM
@Gary and all,
Regards,
xilusma
Yes        I understand that the  point of the  whole  curciuit  is to isolate  the  2  sources of power
I understand   how the  coil  isolated the HV .........  I don't  see  how  the  low  voltage is protected
gary
nightlife
I am not good with circuits but I find that s1r has used the coils coil wire for the ground to charge what ever he has in the container. When the coil fires, it breaks the grounds connection.
What can be charged by connecting a negative and positive and then discharged to the closest ground just by breaking the connection?
What ever can do that, must be what he is using.
resonanceman
Quote from: nightlife on July 03, 2008, 03:10:49 AM
Nightlife
That sounds like the " normal " way to trigger  an  ignition coil
gary
aether22
Quote from: LarryC on July 03, 2008, 12:42:23 AM
But it blew my 10 A fuse on the variac. Will use isolation transformer as you posted next time. Only had 4-1N5404 in series, will get more.
Regards, Larry
Blowing a 10A fuse sounds relatively brute force, or in other words possibly underunity.
If we assume that what S1r did is real then it should be more energy out than we put in electrically.
So the question is, are there 2 ways to do this or only 1?  Is there a way that takes over 10A and another that pulls far less (such as Luc's first version) for the same result?
Is the isolation that S1r went to efforts to get required to get the effect OU, or can the circuit be grounded?
Very rude of me to ask questions without answering any of 'em I know....
