URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
Shiver
I would imagine that if you just cut off the outer electrode and install a washer in it's place to bring the outside of the plug housing upto the same height as the inner then you would get a decent spark that would arc radially in different directions each fire, and give you much less chance of having water block the path.
Spokane1
Dear Non-Funded Researchers,
Here is a typical current pulse through a modified spark plug with a .125" Gap using a 5 UF capacitor charged to 325V. The event lasts about 12 uS.In this case a 100 Amp pulse was observed using a Pearson 110 Current Transformer. This pulse was done in a chamber without any water vapor and is intended to be the base line for exploring these water assisted explosions.
I have photos of the set up and detailed write up to go with it but this program bounced it for being to big and then erased all the text that took an hour to compose.
This is an attempt to see if there is any connection between this thread and the work of Marvin Cole (E.V. Gray) and his "Converter Switching Element Tube" (CSET).
Spokane1
goldenequity
Thanks for working on a baseline Spokane.... great idea. ;D
Tinker
Thank you for your efforts and your contribution, but for the less learned of our group could you help us understand what you posted.
Be
Well
Tinker
resonanceman
Quote from: Spokane1 on July 07, 2008, 12:29:27 AM
Spokane1
Spokane
There  have been claims  that  this  circuit   creates a radiant event  .  Like  the  grey tube does .
Im my opinion  it is not proven yet .   Although  it does  fit  the description  pretty well .
Personaly I  don't  think I  will ever be convenced  it is  a true radiant event  by a spark .
If  it is  a radiant event  then  if we can make a string of them we can  put a  collection  grid  around it and  charge a battery or light a bulb or something  .
Scroll  back to reply 561 if you  havn't read that already
gary
