URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
hartiberlin
Hi Luc and Ossi,
maybe you can try if the sparkplug electrode materials really have much
influence of the reaction and also the used area of it.
Maybe you can just try to use a bigger metal area, so
just use 2 iron or copper plates or graphite plates and
see, if you bring them close enough and have them wet,
if the whole area will explode or only there, where the spark jumps ?
So maybe if you have at least 1 x 1 inch area of 2 wet plates,
will the whole water on all the area explode or
only the water being directly inside the sparking area ?
gotoluc
Quote from: callanan on June 28, 2008, 07:19:44 AM
Hi All,
I have fully replicated the effect that Luc describes and shows. It is truly astounding! With no water and a dry spark plug you get normal cap discharges and nothing special. Spray a bit of water and it is like fire crackers going off! The water will continue to explode when fired repetitively until it has all gone from within the spark plug. This can take a minute or two at a 1 second repitition rate. The more fine the water and spray, the more powerfull an explosion and it is undoubtedly an extreme fuel based explosion which in this case, the fuel is water. Please see my video where I have tried to capture the explosions with angle shots but my digital camera does not do justice in representing the true power of the explosive ignitions of the water. This is very real stuff indeed folks!
http://www.youtube.com/m1a9r9s9
I am attaching a circuit diagram of my test setup and some pictures to this post. Regarding the circuit, the most important part of the discharge side is the need for a high current high voltage diode. I have simply used 16 x 1N5404 in series. They are 4 amp diodes. My oscillator is a basic radiant oscillator that I released years ago and is a very good and simple radiant energy oscillator. As far as RE being at work here, we all need to do much more experimentation to prove it is required as opposed to convention energy. I do know that my simple circuit uses 1-1.5 amps input at 12 volts and this energy input can be brought down significantly with more efficient circuit design.
Regards,
Ossie
Hi Ossie,  ;D ;D ;D Excellent work ;) I am very happy.
I don't know if anyone here would have ideas how to capture a photo of the orange red glow that is going on when the water spray is applied to the plug when it fires?
It would be nice to post a picture of that since the video camera does not pick it up.
Luc
hartiberlin
Quote from: gotoluc on June 28, 2008, 11:32:37 AM
Luc
Hi Luc,
put a bit of Strontium Nitrate into the water,
then it surely will glow red ! ;)
I used this when I still designed my own fireworks... ;)
By the way,  one could also try to use this water explosion for a MHD
generator.
see:
and
http://elgersmad.homestead.com/files/mhd/mhd.html
So try to put near the spark gap a magnet and capture electrodes 90 degrees
to your sparkplug electrodes and you will capture some negative electrons and
positive ions, which will charge up your capture electrodes.
Would be interesting to see the captured electric pulse on these electrodes.
Maybe this way we could reconvert the exploding water into electricity
and the efficiency might be higher than in a fuel cell ?
gotoluc
Quote from: pese on June 28, 2008, 07:35:30 AM
If avaiable use Faster Diodes than 1N5400 series.
Use AVALANCHE diode to protect against hi voltages peak.
so i tpmt need 16 diodes.
with faster diodes (switching time) you have also more efficientce in output voltages -
Gustav Pese
Hi pese, thanks for looking at this topic and offering your advice to help ;D
Luc
gotoluc
Quote from: Dread on June 28, 2008, 08:14:54 AM
Gotoluc & Callanan,
You might want to think about replacing the water sprayer with steam from an electric kettle, this would simulate heated vapour in ICE (pre-ignition) also, if you could run the steam through a strong EM field prior to igniting it, the effects might be worth the effort.
BTW. I believe S1R's surge issues are nothing more than inconsistent water metering.
Rgds. to all.
Hi Dread, thanks for coming to this topic, a good suggestion also to see if steam has the same effect or does it get better or worse. A definite simple test to do today.
Luc
