jibbguy
Congrats, Luc , this is a wonderful project and a great example of the Open Source Energy movement!!
22vision
wow! I think I just some ious BOOM here I have a 555timer driving the coil with an MOSFET
I was getting the standard little spark from the plug. I just hooked up 2 3KV DC caps from an
old monitor across the plug and I am getting some very nice plasma sparks and what I consider
loud from previous tests. if I dribble some warer on it id gets much louder and there are flashes
of red all around the plug!  I think I am on to somthing here with this. the 555timer is just to pulse
the coil it is around 60hz and I can adjust it. I am going to experiment a bit more then try and get
somthing out to you all.
I will be on this weekend so feel free to ask questions.
22vision
maybe I will get a pic and so you can see  :  )
gotoluc
Quote from: hartiberlin on June 27, 2008, 03:01:54 PM
Luc, can you please try to remove the big diode and just use the cap charge and no connection from the inverter to the
sparkplug ?
Will this be the same discharge spark or does the rectified AC also flow via the spark discharge and make the spark bigger ?
Many thanks.
Regards, Stefan.
Hi Stefan,
before starting this topic I did do many tests to find what works and what does not. It took about 30 hours to get it down to just this simple circuit. You should of seen the box of all the crap of stuff I took away before doing the video. One thing I can tell you is forget about what conventional electronics says should be.
To answer your questions above, no discharging the 150uf cap charged at 108vdc through the coil only with the rest of the circuit removed will only do a standard spark.
Also if I remove only the diodes and discharge the cap nothing happens.
Thanks  ;)
Luc
gotoluc
Quote from: 22vision on June 27, 2008, 05:06:43 PM
22vision
Wow :D , that's great news, mostly if you are seeing the red glow around the plug ;).
Keep us up to date.
Luc
kremlin01
Luc, great topic look forward to further developments.
Going to sleep on it now, if I can sleep!
Regards Bren.
