gotoluc
Quote from: vince on June 29, 2008, 07:05:49 PM
Hi Gotoluc
Great work!
I tried a simple test to see if I could get the water to "burn" and it wasn't that hard to do. I used a small TV chassis to feed High voltage to a pair of microwave capacitors wired in parallel and then to a spark plug with the resistor removed. It would charge the capacitors and discharge at it's own frequency with a very strong white spark.  When I sprayed water on it (FINE MIST) it would flash a bright orange flame much larger than the original spark.  The effect lasts for several other sparks until the water burns off.
I am truly amazed that a simple high voltage setup can actually flash water.
Here is my setup.
http://picasaweb.google.com/vincemormile/WaterTest/photo?authkey=gITG9gFcghI#5217442680332392498
Vince
Hi Vince, good for you :D I think we will find many possible variations on this basic circuit idea.
Keep up the good work ;D and find what you can do with this circuit, like can you light fluorecent bulbs with it and how many.
Have fun and play safe and thank for sharing.
Luc
gotoluc
Quote from: hartiberlin on June 29, 2008, 06:52:25 PM
@Luc,
your new circuit makes not much sense to me.
The effect is, that a high voltage spike from the ignition coil
creates a ionized conductive channel for the low voltage cap charge
to be discharged and instantly creating steam and electrolysed HHO,
which burns off in a Bang...
Regards, Stefan.
Hi Stefan, yes I know my circuit is flawed. I had a quick vision and tried to transfer it in electronics in a hurry just before going out for some hours. As I said before my electronic skills are not strong. What I will do is write my thoughts and someone else can create the circuit.
At anyone and everyone, please share this topic with everyone you have in your email address book and ask them to do the same regardless of what you think. We need this out to the World.
Luc
Sprocket
I realise that the ultimate goal is to replace petrol/gas entirely, but seeing as 99% of cars will need their timing retarded, (non-trivial, especially as 99% of cars on the road are of the newer variety) wouldn't this idea on its own result in a significant increase in mpg?  It would be much easier to test on a real car engine as well...
xbox hacker
VIDEO UPDATE!!!!
http://www.youtube.com/watch?v=HuK80kL6O64
I am so soorrry about the quality, its from a phone....LOL  ::)
nightlife
xbox hacker,
QuoteVIDEO UPDATE!!!!
What is the excessive clicking noise in the back ground? It doesn't match the time of the spark and I hear more clicks then I see sparks.
