dopey
Try this experiment if you really want to know the comparative energy release efficiencies of water/air vapor versus gasoline/air vapor as ignited by a plasma arc.
Once you have successfully replicated the hardware and have produced the successful experimental subjective results of "a bigger spark when you spray water on it", then mount your sparkplug, tip inward, in a five gallon steel gasoline Jerry-can.  Put the sparkplug near the top.
Do these two experiments:
First, starting with a completely clean can (no gasoline residues), spritz your water in there.  Fire it off after sealing the can up tight.
Now, do the same exact experiment but spritz a fine mist of gasoline or alcohol in there...use an equal amount as you used water.
Now light it up!  You want to talk "bigger spark" huh?
Be sure to wear protective goggles and a flak jacket and maybe stand in the next county on the second half of the experiment.   ::)
gazzzwp
My biggest concern about this work is it's feasibility at high frequencies.
Nobody to my knowledge has demonstrated that the concept works above frequencies of a few hertz.
We need to work on solid state switching now, to prove that the effect works between say 10 and 70 Hz, otherwise I feel that  effort will only be wasted.  Relays are just not viable for this kind of work.
The big problem as I see it is that all circuits so far rely on huge capacitors and I see no way of incoprorating that into a high speed circuit.
Gazza
Dread
I was wondering when the M.I.B would join the thread. Listen to the sub frequency and you will hear ''Freedom of thought is dangerous, we are the institution''.  Getting too close are we?
D
dopey
Quote from: Dread on July 31, 2008, 04:09:07 AM
I was wondering when the M.I.B would join the thread. Listen to the sub frequency and you will hear ''Freedom of thought is dangerous, we are the institution''.  Getting to close are we?
D
For you, I would recommend forgetting the goggles and flak jacket.  Just sit on the Jerry-can naked.   :-*
Really, is that the bottom line here?  Is that the best you can do when the absolute foolishness of another ill-conceived experiment is revealed clearly?  MIB?  I'm sure they exist, but the chances of this thread resulting in anything that threatened the "status quo" are about nil plus or minus nothing.  The MIB budget is, I would imagine, reserved for actual threats.
AbbaRue
@Gazza
I covered high speed operations in post #1113.
Charge up multiple capacitors at once and switch from one to the other as needed.
