goldenequity
@ Sam
Is it possible for you to "hang" (hold on to) this drop of water .... and place it into the radius of the plasma effect?
I've been very curious to know the explosive effect with this much water available to the plasma
without "drenching" or simply "wetting" the electrodes.
allcanadian
@SPP-48
Your circuit diagram is Tesla Patent 609250 which is quite different from conventional ignition circuits. Tesla utilizes a self induction coil (H) to charge capacitor (G) when contacts (a,b) are opened.What is not readily apparent is that when contacts (a,b) are closed there are two series circuits present---- one consisting of capacitor G, self inductance coil H and the source battery. The other series circuit consisting of capacitor G, primary F and contacts a,b. If the coil H were to have a high self inductance and the capacitor G a small capacity then G could be charged to very high voltages prior to discharging through primary F where it is stepped up yet again through K. We should also consider the difference between charging capacitor G with the source current alone versus an inductive discharge current from self inductance coil H. Tesla and T.H Moray made statements regarding the fact that if a resilient medium were disrupted in some way this medium could produce oscillations and we assumed they were making reference to qualities inherent in LC circuits. But if we considered capacitor G as having properties of oscillation within itself and without (external field interactions) as if an electrostatically charged drum skin were struck then discharged we could see these internal oscillations would travel within the discharging current and effect the qualities of the current .
SPP-48
@goldenequity
Good idea.
I can let the drop hang just above the electrodes and set off the spark using Luc's circuit.
I will try that tomorrow.
Sam
SPP-48
@allcanadian
Thanks for the detailed explanation. It sounds as if it may be worth pursuing further. I am not an electronics person, so if anyone could translate Tesla's diagram into a circuit using available components and specs I would be happy to build it. If we can increase the spark + add water we may progress further.
Cheers
Sam
goldenequity
