happyvalley808
Quote from: scalar wave on October 17, 2008, 10:33:55 PM
JSTADWATER,
GREAT V8 PLASMA SPARK WITH WATER SPRAY.
PLEASE TRY A COMPARISON WITH SALT WATER SPRAY -- OTHERS HAVE SUGGESTED YOU GET A SLIGHT ELECTROLYSIS ACTION ALONG WITH THE WATER EXPLOSION.
NOBODY RESPONDED ON THE MOT TO MOT ISOLATION TRANSFORMER OH WELL TOO BAD.
MIKE
Thanks for the MOT to MOT isolation transformer idea, have you tried it yet ??
HV
happyvalley808
@All,
I believe i have found an inexpensive supplier for isolation transformers...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=120132004551
They are 1:1 120v in 120v out , 120w
Hope this helps.
HV
djzissis
Quote from: gotoluc on October 17, 2008, 06:18:54 PM
@Greg and anyone interested,
I've been thinking about the isolation transformer cost, availability and all this. It seems to be the only down side at this time for replicators.
I have an idea ;D... MOT's are easily available and can be next to free. When you think of it ::)... it is an isolation transformer!... just at a much higher voltage on the secondary side. I propose we move your VexUs circuit to a new level... HV that is. Use a MOT as isolation transformer and feed the HV directly to the circuit. Obviously you would have to drop you Capacitance value by much and make your FWBR with HV diodes but I think that would be the only thing you may need to change. Also many have been noticing the benefit of Higher Voltages.
So what do you think of this idea? Are you willing to test it? if so I would suggest using a Variac to start at a low voltage and slowly raise it if it works. Maybe the .7uf to 1uf microwave oven capacitors could end up being the correct size for the circuit?
Just an idea. Let me know what you think of this.
Luc
Hey Luc!
Very good idea!!
In the past, when I saw your video testing between HV and LV capacitors, it passed my mind to use a "MOT" as a part of the circuit.
It would be really good and beneficial to step up same volts. Beneficial because the spark will be more stable and way bigger as seen in your video!!
Something else that would change in the circuit, (i am not sure) may be the resistor. More Ω will be needed, so less power consumed. Just a thought.... I am not sure about that.
Thanks Luc!!
Zissis
P.S: Gotoluc's video testing Capacitance vs. Voltage is here: Link to Video
happyvalley808
@All,
Revizal on youtube has ran Gregs "VexUs" circuit on a modern SUV.....
http://www.youtube.com/watch?v=x-pI0qb-Bz4
HV
gmeast
Hi all,
Wanted to post a VexUs circuit configuration update. I have moved the current limiter to a more logical location and in so doing made a hard mate between the FWB + and the chassis ground. The potentials are the same as the original and the theory is the same. What I've done should make filtering, shielding, instrumenting and all other interfacing easier to do.
Peace,
Greg
