Thanks to ALL for your help!!
magnets and electromagnets
Started by pinestone, June 28, 2008, 12:51:26 PM
pese
Quote from: resonanceman on June 29, 2008, 11:05:10 AM
Interesting  little  device
The URL  at the end didn't work
gary
possibly
or
surpressed ?
sure is:
unwanted invention.
and:
we belive tto mutch
and know "near" nothing
nightlife
Here is the url at the end and as stated, it does not work although it does show evidence of working in the past judging by the topics of the different possible selections.
http://wuerth-ag.com/
My guess is that someone is trying to keep it secret. It looks easy enough to build and I am assuming that once it brought up to speed, it would take much effort to keep it at that speed.
It would take some testing to see what happens when work is applied.
resonanceman
Quote from: nightlife on June 29, 2008, 09:08:22 PM
It looks  like a  pulsed  flywheel  system
It does look pretty easy to build  for anyone with  metal  working   equipment .
I  suspect  that  starting  it is a little more  complex  than   they  made it look .
It probably  has to get  going fairly fast  before  you   can  pump it  up  by moving  the  top wheel  back and  forth .
gary
Onevoice
It might be nothing, but it did look to me like the guy turning the wheel had his muscles tensed a bit too much for a low energy pulse on the wheel. The real test is to measure how much energy is required in the pulses to keep a constant RPM going when the system is under a measured load.
quote: The needs of the one outweigh the needs of the many - Capt. James T. Kirk
pinestone
Quote from: vzon17 on June 29, 2008, 08:37:08 PM
You are correct the magnetic field is not static. Also when you turn off the current the magnetic field does not stop it collapses back down and generates an electron flow in the wire which is of a different nature than the electricity that made it in the first place. the magnetic fields are in constant motion. there are two vortexes of energy on each pole.
Yes, an electromagnetic field generates a reverse 'inductive kick' when the magnetic field collapses. I was referring to the field possessed by a magnet.
The domains inside the ferromagnetic material that makes up a magnet are aligned in such a way that their electrons spin n-s or s-n.
Somehow this atomic level spin leaves the surface of the magnet and has the ability to align the domains of other ferric materials over a distance.
If the electrons are spinning, that means they are moving, doesn't it?
