MARS and back in 2 days...
Started by hartiberlin, June 28, 2008, 03:18:34 PM
IotaYodi
Oscillating tuned high frequency electro-magnetic fields using the aether. Like an electron riding a conductor?
What I know I know!
Its what I don't know that's a problem!
onthecuttingedge2005
Gravity has no propulsion power in Space, Gravity is a Tensor Carrier Field, it has no value as propulsion, what are you going to gravitate off of in deep space?
Light Ships are the future of interplanetary travel and interstellar with induced wormhole vectoring.
I might draw one up but maybe you already know what they look like. This system doesn't use a secondary source of external power as in NASA's design. it has its own power and drive system. there will be nothing new under the Sun.
when inducing a wormhole, the parabolic iris effect is lens shaped, the inverse Archimedes spiral opens the wormhole, the focal length of the parabolic vectoring determines the location the other end of the wormhole exits. so your inverse Archimedes Spiral has to be parabolic to determine where your spaceship will appear otherwise it would be uncontrollable where you exited.
There is no need to travel the distance.
nice little song to fit the bill.
http://www.youtube.com/watch?v=__PU5CVSegg
Jerry ;)
Hyperbolic spiral
triffid
I read somewhere that 100,000 tons of dust and other material fall to the earth each and everyday.With the space evelator on its way(20 years?),then solar sailing to other worlds.I think we should develop ways of mining this material already in space.Then we can build whatever we want without the cost of taking it from the earths surface.triffid
triffid
If we mine the material that falls to earth each day before it falls to the earth.We should see a lot of cost savings for our effort in space.What could be done is simply put a negative charge on the mining eqipment since a lot of the dust and matter is positvely charged from the suns inflence. Negative charged nets to suck in the positively charged dust particles could cover a very large area for a very low cost.triffid
triffid
You can get energy from gravity.Io gets heat energy from jupiters gravity and the other 3 moons near it.Its crust is flexed enough to generate a molten core.So nature has already shown us how to get heat from gravity.And we have used gravity on certain spacecraft to pick up speed. triffid
