Super Simple way to understand the TPU
Started by innovation_station, July 02, 2008, 07:49:15 AM
MACEDONIA CD
I ALMOST FORGET  <<<THE  SMALL TPU WHIT  62 VOLTS IS MADE OF PLASTICS MATERIAL
ASK YOUR SELF WAY   THE MAGNET FILD  IS   NOT HAVE POSIBEL  TO  MOVE IN TO THE PLASTICS MATERIAL AND YOU SEE THAT   WAY IS PLASTICS   ANDD SEE  THE   TPUs   IS  NO T HAVE MORE <kg>  what  is hapend if is plastics how  to transmit  elktromagnet fild  like this
but is not elktromagnet fild   there is  ather
agentgates
Quote from: innovation_station on July 07, 2008, 01:17:04 PMuse a transformer  a spark gap and a light bulb
then you tell me it dont work
No, you are telling me it doesn't work and trying to put foreign words into my mouth. And after I learned how you performed the measurement I am not wondering at all. If you don't know that how to calculate induced current on an inductive load that is not my fault and the minimum I would expect is some respect, maybe some questions in an acceptable way and not to try set OTHERS as a fool if you make mistake.
Why would I tell you it doesn't work, when it generates high voltage at high current on my workbench? Why are you judging an experiment that you don't even know that how exactly has been performed?
My request would be to you to show as much respect to others as much you are expecting from them.
Quote from: innovation_station on July 07, 2008, 01:17:04 PMi mesured amparage yesterday  ;D ;D ;D
how much did i mesure on my real cheep meter ??
Probably you measured nothing. You'll never measure a ns spike amperage this way. (by your "cheap meter") But you can calculate the induced current since you know the resistance/wattage of your light bulb and the voltage of your spikes.
innovation_station
dude im telling you all to try this lil test
did not mean to offend you
there 2 engeryies at play here
the engery you put in and the engery that is returned upon disruption
it is posobile that my digital meter was affected by the emp .....    but do tell me why my transformer sings under load??
ist
innovation_station
so i changed my reed and my ist neo zap vibrating spark gap  ;D :P to just a plain vibrating spark gap   it all works well
i have used reeds in this lil setup but they get to hot and burn out i used the ist neo zap it spits radition so back to the good old  plain steel spark gap
seams to be safest  but let me tell you the neos are verry impressive not just the plasma flame i get but the electrical out put too ;D
for my vibrating steel or neo gap i use a fish tank air pump!!!!   in fact it works well with the reeds too  ;D  sure there are better ways but this was easy  and it uses 4w but that is no concern at this time the point is it is ac and vibrating and i can adjust it easly
ist
aleks
I've did "impact test" with a another piece of iron (can't measure its weight right now, but it's probably 6-8 kg).
Response is much more complex, of course, since this piece of metal has a complex concave form.
However, frequencies present in the previous test are also among frequencies of this test.
They are:
2.140kHz (minor), 5.480kHz, 6.940kHz (minor), 11.5kHz - very close to already mentioned frequencies if you consider octave resolution. Highest harmonic this time is 7.290 kHz.
Attached is an image of both iron pieces. Small bar is what I used to strike iron.
