S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
0 Members and 18 Guests are viewing this topic.
Bruce_TPU
Quote from: atlasman on July 15, 2008, 10:32:52 AM
You the man bruce!  Apparently your smart enough to do all what you say you will, or you wouldnt have said it all  ;D.
Im looking forward to seeing the final "WORKING" product.
atlasman
Not me, but "We".  Working = HV transformer
Whether this will work for the needs here or not, I can not speculate.  Again, we are NOT going to be testing this with the ignition coil, plug setup, at all.  We are engrossed in another build.  Our needs just happen to overlap with the needs here, at this time.   So yes, we will do what we can to make this work.  ;)
Cheers,
Bruce
xbox hacker
I cant believe that he wasted time on making a video that shows him taking it apart!!!!! The effort could have been used in showing us EXACTLY how the winding directions go...and various other questions. What an assclown!!!! But for sake of argument i will study the video and try to get the directions right...i got nothing else better to do...i exploded my HV diode  ;D
fritz
Pulseshaper ...
I wouldnt take the exact replication of this coil too serious.
You have a problem:
The pulse is too short - energy is consumed too fast - less
output.
So you have to build something which wides up the pulse.
This can be some inductive(coil) or capacitive thing (even mutual
capacity).
The ingredients are quite cheap, nail, wire, metal can.
There is no sharp go/nogo - there should be some experience
after few hours playing around.
I think the metal case/can casing adds a mutual capacity
which couples to the coils - and is of high importance.
The operation without the casing will be different.
rgds.
resonanceman
Quote from: xbox hacker on July 15, 2008, 05:11:53 PM
Xbox
I think that people here  jump to conclusions  much to quickly      and  resort to name calling  much to often .
Could it  be that  Sr1  is doing the best he can ?
As  you  are  watching  the video  for  details about how the  coil is made .
Turn  up  the volume .
Watch  AND listen   as he  pulls on  the  ends  of the last coil .
gary
Bruce_TPU
Hello all,
Based on the video and .pdf ALL of the "drawings" on page 1 of this thread are INCORRECT.  Might be why it doesn't work.  ;)
Hope that helps some.
Cheers all,
Bruce
