S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
capacitor70
Plasma generation using coil NO DIODES....
Thanks Shanti....
Circuit is not much fast, but it can work fast with CDI ignition system and proper capacitor and transformer,
I am trying to reduce number of turns of coil to get much better results.....
See Video
http://www.youtube.com/watch?v=eFupa63jY4M
whopper1967
I am amazed every time I log on,very nice job capacitor70. :)
xbox hacker
Quote from: Bruce_TPU on July 15, 2008, 09:38:42 PM
Hello all,
Based on the video and .pdf ALL of the "drawings" on page 1 of this thread are INCORRECT.  Might be why it doesn't work.  ;)
Hope that helps some.
Cheers all,
Bruce
can you enlighten us as to the proper setup?
Bruce_TPU
Quote from: xbox hacker on July 16, 2008, 09:19:44 AM
For one thing, at 58 seconds in the video, you will notice that the lead of the coil that you all have labeled "third coil" in the drawings on page 1, is wound OVER it's own lead.  Or you could wind the coil and then feed one lead back THROUGH the coil.  This is what I referenced earlier about the "90 degree rule", or you can look up otto's old five turn experiment.  It is a GREAT way to increase voltage.
So you can change the picture accordingly.  There might be more to change, I'm still looking... ;)
Wife is in surgery, so I will have some time to review some more.  The devil is ALWAYS in the little details.
Hope that helps,
Bruce
xbox hacker
Quote from: Bruce_TPU on July 16, 2008, 09:35:47 AM
Hope that helps,
Bruce
It has been updated!! Do you have a link for otto's stuff?
